Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 09-14-2011, 01:53 PM   #1
Attach riser to inside wall for concrete forms
I am building some forms for concrete stairs leading to an outdoor porch. The right side of the steps will be open (going up). The left side will be against the side of the house. The side of the house is standard face brick. Is there a preferred method or any suggestions for attaching the riser forms to the brick surface on the house?
malekclan is offline   Reply With Quote
Old 09-14-2011, 04:59 PM   #2
If you want that stair to stay there, you will not pour the concrete against the brick. Dis-similar materials will move at different rates and it won't take many weeks and you'll have a mess. You need to form away from the brick.
TrapperL is offline   Reply With Quote
Tags
concrete riser forms
How to attach insulation panels to block wall BRO931 Building & Construction 3 10-29-2010 05:01 PM
Condensation inside wall on vapour barrier rovers1973 Building & Construction 1 05-14-2010 11:00 PM
Need advice on pouring slab inside existing wall. bmwbykrydr Building & Construction 2 04-05-2010 11:11 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Minimum Clearance to Vent Inside Wall? MikeinBurien Plumbing 12 12-06-2005 12:03 AM
