Arced Or Bent Cabinet Face - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-12-2009, 11:28 AM   #1
arced or bent cabinet face
Can anyone tell me where to get pre-bent or arced wood for a half round cabinet face? I know there out there somewhere.
riverrite is offline   Reply With Quote
Old 09-12-2009, 06:35 PM   #2
Remodeling Contractor
any cabinet or plywood supplier will provide this. Or best to just buy the doors you want already made. Many companies are available online.
Old 09-13-2009, 12:40 AM   #3
Registered User
Termite's Avatar
It is normally done on a shaper, and isn't going to be an off-the-shelf item anywhere. As Bob said, you'll need to go to a cabinet shop.
Old 09-14-2009, 08:21 AM   #4
General Contractor
You can make these yourself. There are several ways to do it and all have been covered in various publications. You can start with the complete manual of wood bending by Lon Schleining (sp?). If you're planning on building the cabinets yourself you need to learn how to do this or you may as well pay a shop to make the cabinets for you. You can also do a Google search on bow front cabinets or arched face frames and you will find some pretty good examples of how to do this kind of work. Good Luck and have fun.
ARI001 is offline   Reply With Quote
Old 09-14-2009, 10:45 AM   #5
Old School
cabinetman's Avatar
There are several ways to make bow fronts or curved sections. You could use bending plywood that is sold specifically made to bend, which once in place can be veneered. Or, plywood can be kerfed on the backside and bent. Fronts can be done in solid wood and "coopered" to form the curve.
For doors and faceframes, solid wood can be cut from stock on the curve with a bandsaw, or can be made with thin strips of the wood glued up to a form to create a "bent lamination". Wood can be soaked or steamed to achieve a curve. I prefer the glued up method as it affords less "spring back".
If you describe exactly what you have in mind, You'll more than likely be able to get "talked through" the process.
cabinetman is offline   Reply With Quote
hanging 9" kitchen cabinet (wall) and hit air duct, no stud phunam04 Building & Construction 4 06-16-2009 10:08 PM
Type of box / how to feed power for in (face of) cabinet outlets? jamiedolan Electrical 2 03-18-2009 11:13 PM
pocket hole joinery for cabinet doors? Jeremy Hillary Boob, PhD Carpentry 4 03-09-2009 05:26 PM
Installing kitchen cabinet in precise manner janny Carpentry 8 01-15-2008 10:59 PM
