Applying Laminate To Waterfall Edge On A Counter Top. - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-02-2008, 09:30 AM   #1
Applying laminate to waterfall edge on a counter top.
I purchased preformed counter top with the attached backsplash and a waterfall edge. I also purchased a 48 x 96 piece of the same laminate to custom build a breakfast bar. Anyone have any ideas of how to apply the laminate to the waterfall edge? I was told by someone that you need to heat the laminate with a heat gun???
lmpasker is offline   Reply With Quote
Old 04-02-2008, 06:07 PM   #2
Rewards Points: 5,332
Waterfall edges are almost impossible to do outside the factory environment. Experiment with a scrap piece to see what I mean.
Ron
Old 04-02-2008, 06:34 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
You're better off purchasing another post-form section for your breakfast bar, or doing a standard edge with the laminate material you purchased.
- Build Well -
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing/Siding 32 02-15-2008 02:10 PM
Repairing scratch in laminate counter Keyo77 General DIY Discussions 2 02-03-2008 01:00 PM
laminate floor vs subfloor 4 railing mount gdub Flooring 4 01-04-2008 02:42 PM
Laminate Floor in Sunken Room w/ Tile on Edge z0s01 Flooring 1 02-20-2007 10:44 PM
