-   -   Applying laminate to waterfall edge on a counter top. (http://www.diychatroom.com/f14/applying-laminate-waterfall-edge-counter-top-19402/)
lmpasker 04-02-2008 10:30 AM
I purchased preformed counter top with the attached backsplash and a waterfall edge. I also purchased a 48 x 96 piece of the same laminate to custom build a breakfast bar. Anyone have any ideas of how to apply the laminate to the waterfall edge? I was told by someone that you need to heat the laminate with a heat gun???
Ron6519 04-02-2008 07:07 PM
Waterfall edges are almost impossible to do outside the factory environment. Experiment with a scrap piece to see what I mean.
Ron
AtlanticWBConst. 04-02-2008 07:34 PM
You're better off purchasing another post-form section for your breakfast bar, or doing a standard edge with the laminate material you purchased.
