Anyone Build One Of These? - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-20-2013, 03:57 PM   #1
n2omichael's Avatar
Rewards Points: 115
Anyone build one of these?
I was thinking of building one of these, could probably do it for less than 2K, any thoughts or input?
http://ontario.kijiji.ca/c-buy-and-s...AdIdZ520644548
n2omichael is offline   Reply With Quote
Old 09-20-2013, 04:12 PM   #2
Maryland
Just one question. Why would you want to swing TOWARDS the fire?
Pittsville is offline   Reply With Quote
Old 09-20-2013, 04:15 PM   #3
n2omichael's Avatar
Rewards Points: 115
You would rather swing AWAY from the fire with your back to it? And all the other people sitting with you?
Old 09-20-2013, 04:53 PM   #4
Rewards Points: 1,690
If I can quit laughing I'll give my opinion.
OK, I've regained some composure. I'm thinking it needs to be hell for stout unless the swings are used in unison with correct timing or it may act like an out of balance washer on spin cycle. Interesting project and let us know the result.
Old 09-20-2013, 05:00 PM   #5
n2omichael's Avatar
Rewards Points: 115
I wondered that too? Luckily I rarely have more than 5 or 6 people for a bonfire, guess I'm not that well liked? LOL
I had planned on using 6x6's for the structure and sono tubing them into the ground. I figure adults usually only gently "swing" a little, but, children although later, like to swing a little more.
I have a pile of bonfires at the cottage, and to be honest I was just looking for something different, instead of the usual "lawn chairs on gravel or patio stones" for a fire pit. Any other ideas or suggestions are MORE than welcome, Thanks!!
Old 09-20-2013, 10:49 PM   #6
Maryland
Why not build some bench gliders? You get the same general effect without having to worry about the design/strength of that structure. Heck of a lot safer then swinging around an open fire too. Just my opinion.
Old 09-20-2013, 10:55 PM   #7
n2omichael's Avatar
Rewards Points: 115
That could work, I would have to buy them since I have no idea how to build a glider, I kinda like the overhead structure, but, I guess I could build a pergola or something.
As for open fire, I had planned on building a granite firepit about 3x3x 16" high and having fires in that, they would be small fires, more for ambience than anything else. Not planning on having any Buffalo, NY "5 alarm steel mill fires" lol
Old 09-22-2013, 09:39 PM   #8
Still going...
ChrisDIY's Avatar
Rewards Points: 508
You're going to need some really deep footers
--Chris the DIY Guy
Working on "The Great Wall of Retaining..."
ChrisDIY is offline   Reply With Quote
Old 09-22-2013, 09:41 PM   #9
n2omichael's Avatar
Rewards Points: 115
I only have about 12" of dirt, then it's solid limestone, can drill into the rock, drop in rebar and concrete footings right into the rock
Old 09-23-2013, 09:53 AM   #10
I vote for the sliders also. You don't want to start to swing that thing out of balance and have it topple.
Google "Tacoma Narrows Bridges"
dabeast is offline   Reply With Quote
Old 09-23-2013, 08:24 PM   #11
Rewards Points: 236
that wouldn't be that hard. pre drilling and lag bolts would be your friend. and a few pieces of stainless plate.
Fix'n it is offline   Reply With Quote
Old 09-23-2013, 08:26 PM   #12
n2omichael's Avatar
Rewards Points: 115
Lag it into the rock directly and skip concrete? Or use them both? Either way it's a good idea. (-:
Old 09-23-2013, 09:18 PM   #13
Haverhill Trade 1965
From that picture I bet I know what burns their (burro) the most.
Duckweather is offline   Reply With Quote
Old 09-25-2013, 07:55 PM   #14
Rewards Points: 236
lag the joints. then a piece of stainless on top, lag bolted down. done properly, that thing would basicly stand on its own.
and if you did this = 12" of dirt, then it's solid limestone, can drill into the rock, drop in rebar and concrete footings right into the rock.
oh, when i lag, i mean 12-16" long, at least 1/2", 3/4 even better. and need a impact to drive them into the holes you drilled.
Old 09-26-2013, 01:11 AM   #15
n2omichael's Avatar
Rewards Points: 115
Great! That's pretty much exactly how the deck we built was anchored and it has been rock solid, you can buy the complete kit (minus firepit) for 2K, but I think it could be built for a lot less.
Planning to build First Spec Home, Need Advice ahb2012 General DIY Discussions 53 05-27-2013 06:30 AM
Build up in cast iron pipe bend -> new high pressure toilet to fix? VTJeff99 Plumbing 3 02-09-2012 01:05 PM
How much more would it cost to build another story? reveriereptile Building & Construction 5 01-19-2012 10:51 PM
time to build simple addition bmt1970 Building & Construction 9 03-05-2010 02:06 PM
