Another Door Problem - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-29-2006, 05:33 PM   #1
Unhappy
another door problem
:confused: i just purchased a mobile home. the floors have been remodeled, but they were built to high. it didnt have a door (entry) on it, when i did put one on, i discovered that the door drags pretty bad. considering that the door is plumb, how can i fix this problem? thanx be to anyone who can help.
daustin555 is offline   Reply With Quote
Old 04-29-2006, 11:34 PM   #2
Darylh's Avatar
If I got this right you have installed a entry door
with a cill and the door is so tight that its rubbing
on the cill. If thats right you have a couple of
options. 1-you will have to shave the bottom of the door.
2- The other thing you can do is try to lift the whole unit
up so its not so tight. Myself I would take the door off
and just shave it.
Darylh is offline   Reply With Quote
Old 05-03-2006, 12:30 AM   #3
carpenter
Typically the bottom of newer exterior door has an adjustable sweep ( the rubber part on the bottom).
nailbanger138 is offline   Reply With Quote
