Another Crown Cutting Question - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-19-2008, 11:54 AM   #1
I have almost completed my kitchen cabinet crown molding. I am on my last piece but cannot figure it out. The cabinet is a corner cabinet and it is at a 45 degree angle. I am trying to install the crown on the outside 45 degree angle.
What would I set my miter saw at for this? I have taken some stabs but have been off every time. Any help is appreciated.
HuskySkull is offline   Reply With Quote
Old 09-19-2008, 12:44 PM   #2
the Musigician
DangerMouse's Avatar
Dm
Old 09-19-2008, 12:48 PM   #3
Thanks for the reply I tried the 22.5 and it came out wrong. I am cutting with the crown at a 45 angle on the miter, should I be doing it flat?
Old 09-19-2008, 12:56 PM   #4
the Musigician
it would seem that way, so try it. why would you be set to 45?
DM
Old 09-19-2008, 04:29 PM   #5
Registered User
Termite's Avatar
Put the crown upside down on the saw as though the base of the saw is the ceiling and the back of the saw is the wall. Set the compound cut to perfect 90*. Set the saw to 22-1/2*.
There's no need to use the compound miter feature of a compound miter saw for crown, and in my opinion, doing so complicates the heck out of things.
A lot of people use crown stops to hold the crown at the correct spring angle on the saw, and that works ok. You just have to be vigilant about making each cut with the moulding positioned at exactly the same spring angle. Some trim carpenters use "sleds" that hold the crown in the saw the same way every time. They can be made from plywood.
Old 09-19-2008, 04:45 PM   #6
My trim is too big for my 10' compound saw so I use the compound and miter settings. If you have a big enough miter saw you can cut the crown as thekctermite states.
It's funny you ask this now because there was just an episode of This Old House Hour where Tom Silva shows a homeowner how to do this perfectly when the angle is not exactly 45, 90, etc. For a 45, you take two scraps of wood, place one on one surface with the corner up against the corner of the 45. Take the other scrap and place it up against the other surface with that corner up against the corner of the 45. Take a pencil and mark the outer edge where the two meet. Take a straight edge and draw a line from the corner to the mark and set your miter saw up to match this mark. This is your angle for both pieces. You can test cut the scraps to make sure they line up properly if you wish.
I use this method ever time I cut crown and it works every time.
KHouse75 is offline   Reply With Quote
Crown Molding question or trick? javan Carpentry 17 06-20-2008 05:11 PM
Door framing and crown molding finnishing question amdspitfire Painting 7 06-09-2008 01:49 PM
ceiling white - crown molding color question remodelingagain Interior Decorating 3 06-06-2008 01:16 PM
Jig for cutting Crown Yeti Carpentry 5 05-18-2007 11:20 AM
Angles for cutting crown mouldings sjrhome Carpentry 14 04-13-2007 07:14 AM
