Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-19-2009, 09:19 PM   #1
Annie5 - framing over uneven concrete floor
What is the proper way to frame a floor over uneven cement? When remodeling after a fire, the living area (on a concrete slab) was extended into the back end of the garage (that ell is about 6 x 12') and down the side (3' strip). The garage cement floor is lower than the living area slab by about 2', and it slopes down to the front.
I cannot do the work myself (age and health), but I need to know what I should have done and should be looking for.
I had the 5/8" plywood floor taken off to check that it would be okay to lay ceramic tile there. The framing does not look stable at all.
In some places the sides are fully resting on a cement sill, but not all. On the side of the ell towards the garage, there is a 2 x 8 that really isn’t supported by anything except the cross joists which are in turn supported by the arrangement described below.
From the living area to the end of the ell, there are 2 x 8 joists going across, spaced 12” and 16” oc. On the outer side (what was the back end of the garage), they are hung over the cement sill with notches half way down them. Isn't that too much weakened?
Underneath the joists going across the ell, apparently for leveling, there are pieces of 2 x 4 here and there (no particular pattern) lying on the 4” side against the cement, many with some wedges (even the occasional skinny piece of scrap wood) on top of them as shims under the joists.
Along the living area slab, there is a 2 x 8 resting on a concrete “ledge” which appears to have been chipped out of the slab (or a separator?), but the ledge is so bumpy the board and concrete are not in full contact… there are significant gaps (up to at least ½”) between them for long stretches.
On the outer wall of the strip (toward the garage), there is a 2 x 4 directly on cement (on 2” side), then another board overhanging that by an inch or so, then two boards with sides butting on top of that overhanging by another inch or so. Doesn’t make sense to me.
Also, although there are no cracks in the slab in the original living area, there is a crack in the cement in the portion of the garage incorporated into the living area – a gap of ¼ to 3/8” wide, running crookedly for about 3’. One side of the crack begins butted tight to the cement which separates the higher living area slab from the garage slab, while the other side of the crack begins ¼” or more away from that separator. It appears that the tight part buckled.
This whole thing can't be right, can it? Am I right in thinking I need to have all that taken out and start again? I would appreciate any guidance you can offer, as I would like to be sure it's done right this time.
I don't know what kind of wood is there. Some seems to have a lot of knotholes. Some seems to be treated, but not most.
Annie5 is offline   Reply With Quote
Old 11-20-2009, 08:37 PM   #2
Moderator
Check on your plans for the remodel or rebuild. The approved set by the County should have the detail or your copy. There are certain ways to frame over concrete, in addition to carrying any loads that the old wall had, safely. Adding living space may require additional procedures that we are unable to address without being there as your local building department would know. And.... welcome to the forum!
Be safe, Gary
Clothes taking longer to dry?
Old 11-21-2009, 02:42 PM   #3
I don't have such plans. I live in a very rural town.
Could you please direct me to a site(s) where I can find the information I need?
Old 11-21-2009, 08:02 PM   #4
anne, you must live next to me. i completely remodled my first house and buit the house we live now from below the ground up, and never heard or seen any of this code or inspection stuff. lol
roadhouse is offline   Reply With Quote
Old 11-21-2009, 08:08 PM   #5
Xtreme DIY'r
Do you have any pics that you can post of the existing framing?
Old 11-21-2009, 10:23 PM   #6
I have a lot of pictures and they are loaded on my computer, but I don't know how to get them here (I have been trying).
Old 11-21-2009, 10:31 PM   #7
I know how to email the photos, if that is a possibility.
Old 11-22-2009, 03:35 PM   #8
Will send another six shortly.
Annie5 - framing over uneven concrete floor-2009-11-21-0028.jpg   Annie5 - framing over uneven concrete floor-2009-11-21-0006.jpg   Annie5 - framing over uneven concrete floor-2009-11-21-0007.jpg   Annie5 - framing over uneven concrete floor-2009-11-21-0023.jpg   Annie5 - framing over uneven concrete floor-2009-11-21-0012.jpg
Old 11-22-2009, 04:02 PM   #9
Here are more pics. If something is not clear, please let me know.
Annie5 - framing over uneven concrete floor-2009-11-21-0014.jpg   Annie5 - framing over uneven concrete floor-2009-11-21-0011.jpg   Annie5 - framing over uneven concrete floor-2009-11-21-0009.jpg   Annie5 - framing over uneven concrete floor-2009-11-21-0016.jpg   Annie5 - framing over uneven concrete floor-2009-11-21-0017.jpg
Old 11-22-2009, 04:26 PM   #10
You can see the area where the top framing is wider than what's underneath it, altho you can't see the bottom piece, which is still narrower.
Looking at these, I want to check on whether I missed a crack in a corner of the cement sill where it meets the original living area slab.
All comments welcome!!
Annie5 - framing over uneven concrete floor-2009-11-21-0024.jpg   Annie5 - framing over uneven concrete floor-2009-11-21-0005.jpg   Annie5 - framing over uneven concrete floor-2009-11-21-0001.jpg   Annie5 - framing over uneven concrete floor-2009-11-21-0022.jpg
Options for Cold Basement Concrete Floor? jefferis Flooring 16 12-09-2009 01:23 PM
Broken toilet flange - concrete floor rob1 Plumbing 5 09-20-2009 11:45 AM
Tile over basement concrete floor? BowDown Flooring 2 05-08-2009 09:41 AM
Is it ok to paint concrete floor in winter... dbldee20 Painting 2 02-06-2009 02:06 PM
covering concrete floor collosse Flooring 3 01-11-2009 04:50 PM
