Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 06-22-2011, 08:00 AM   #1
angle for fascia board along roof edge??
I need to put a 1 x 5 fascia along the edge of the roof line on my new garage so that it will match my house. I can't figure out how to cut the angles at the peak of the roof where the 2 boards will meet because the pitches are different. Is there a trick on how to determine these angles? Here is a pic of my garage.
jgcable is offline   Reply With Quote
Old 06-22-2011, 08:15 AM   #2
Measure the angle and divide it in half. Cut each side the 1/2 angle.
If it's 135 degrees, each cut will be 67 1/2 degrees.
Is there enough roof overhang to place the boards so it's still covered by the roof?
Ron
B. Franklin 1759
Old 06-22-2011, 08:43 AM   #3
Yes, I have a 2" overhang on the roof. Thanks for the response. I figured it was something simple.
Carport Lean to Roof Question.. jgcable Building & Construction 31 04-29-2011 06:12 PM
installing foam board on pitched roof David63 Roofing/Siding 5 04-02-2010 12:36 AM
Metal roof with Fan board insulation, Still have condensation trouble rollenrock33 Roofing/Siding 5 01-29-2010 01:06 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
Roof Vent Drip Edge porschedude996T Roofing/Siding 6 02-04-2008 02:03 PM
