Angle Of Cut - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-06-2011, 12:11 AM   #1
Angle of cut
I have limited material and I need the angle I should be mitering for octagon shape
Alcarte is offline   Reply With Quote
Old 02-06-2011, 12:14 AM   #2
Experienced
Jackofall1's Avatar
360 / 8 = 45
45/2 = 22.5
Old 02-06-2011, 10:02 AM   #3
Civil Engineer
Rewards Points: 4,566
Doesn't work that way Jack. See http://www.articlesbase.com/home-imp...es-193794.html
for a complete description of the procedure to find miter angles for polygons. In this case, the correct answer is 1/2 (135) = 67.5 degrees.
Daniel Holzman is online now   Reply With Quote
Old 02-06-2011, 10:12 AM   #4
Framing Contractor
The saw setting for the miter if he's cutting trim is 22.5. If he was cutting a jack rafter for an octagon roof the saw setting would be 67.5.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 02-06-2011, 10:15 AM   #5
Rewards Points: 506
Jack is correct. OP didn't ask what to set his saw at, he asked what miter to make.
jlmran is offline   Reply With Quote
Old 02-06-2011, 10:29 AM   #6
Rewards Points: 472
If you are cutting a octagon like for a school house clock with 8 pieces they are 22.5 degree's cut. I used to mfd school house clock's and they were 22.5 degree's than and still now. Just set the saw and cut. No use to get into the long math of the 67 and 90 stuff just confusion. set at 22.5 and cut for the 8 sides.
del schisler is offline   Reply With Quote
Old 02-06-2011, 10:32 AM   #7
Framing Contractor
He says he needs the angle for mitering an octagon shape. If he's talking about cutting casing or a flat stock for an octagon shape table the miter angle to set the miter saw on is 22.5.
If he's cutting a jack rafter for an octagon roof the saw setting is 67.5.
In plan view the angle is running at 67.5, but what good does that do for the OP for cutting that angle. He needs to set the miter saw at 22.5.
Joe Carola
The Following 2 Users Say Thank You to Joe Carola For This Useful Post:
del schisler (02-06-2011), fungku (02-06-2011)
Old 02-06-2011, 10:38 AM   #8
Framing Contractor
So, you would tell him to make a 67.5 miter on all 8 cuts? What angle would you tell him to set the saw at?
Joe Carola
Old 02-06-2011, 02:09 PM   #9
Rewards Points: 506
Depends on what type of saw. He could be using a hand saw.
The Following User Says Thank You to jlmran For This Useful Post:
Willie T (02-06-2011)
Old 02-06-2011, 02:20 PM   #10
22.5 X 16 faces = 360
masterofall is offline   Reply With Quote
The Following User Says Thank You to masterofall For This Useful Post:
Old 02-06-2011, 03:22 PM   #11
Rewards Points: 472
we beat this one to death
well we beat this one to death. cut 22.5 on each piece for a stop sign
Old 02-07-2011, 10:41 AM   #12
dear god! It's 22.5!!
mrgins is offline   Reply With Quote
Old 02-07-2011, 12:34 PM   #13
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
what is it <.< >.>
OOO I see it is 22.5 LOL
Big N8 is offline   Reply With Quote
Old 02-07-2011, 01:18 PM   #14
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 698
With a universal reverser saw, the angle would be 167.5, but if you adjust the fence 90 degrees, using an opposite hand oppositizer, the angle would be 77.5
WirelessG is offline   Reply With Quote
Old 02-07-2011, 06:01 PM   #15
Sory your wrong, even with a universal reverser saw the angle is 157.5 as you are subtracting the remainder from the 90 - 22.5 = 67.5 + 90 now your doing a 180 flip so your minus half of that and then subtract the remainder of the 90 - 67.5 = 22.5, with the opposite hand oppositer the angle would be 67.5. There would be no need to adjust the fence 90 degrees if one just spatialy reverses the process you can then set the miter at 22.5
Is It Okay To Hang A Sheet Of Drywall On An Angle? moondriver Drywall & Plaster 12 05-01-2009 04:22 PM
off angle drywall hanging/finishing? ponch37300 Drywall & Plaster 2 07-14-2008 07:13 AM
Tight drilling angle fw2007 Electrical 8 05-31-2008 10:33 AM
Staircase wainscoat angle DIYPRO Carpentry 5 04-08-2008 05:12 PM
Brick Veneer on steel angle iron sandyman720 Building & Construction 3 07-09-2007 09:21 PM
