Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 07-27-2012, 02:28 PM   #1
Angle of cut
I need the angle I should be mitering for a decagon shape, 10 sided shape.
bo1958 is offline   Reply With Quote
Old 07-27-2012, 02:38 PM   #2
Angle of cut
What should the mitre saw angle be for a decagon (10 sided) frame be?
Old 07-27-2012, 03:06 PM   #3
Angle of cut
Depends. Are all sides equal? And are you just trying to miter, or compound miter? Are you trying to make some kind of flat picture frame or?
CopperClad is offline   Reply With Quote
Old 07-27-2012, 03:15 PM   #4
Super Moderator
Angle of cut
Actual angle--36 * miter angle 18*
oh'mike is online now   Reply With Quote
Old 07-27-2012, 03:17 PM   #5
Angle of cut
All sides are the same. I'm making a decagon (10 sided) waterbed frame, and the side boards are 1"x 9"x 29". The boards will be on edge, so I need the angle to set my mitre saw at. Thanks.
Old 07-27-2012, 03:30 PM   #6
Super Moderator
Angle of cut
360 degrees in a circle--divide by the number of corners--then half of that for the miter angle--
Old 07-27-2012, 03:45 PM   #7
Angle of cut
For shapes in a simple plane ...
180 degrees divided by the number of sides
examples
180 / 4 sides = 45 degrees
180 / 6 sides = 30 degrees
180 / 10 sides = 18 degrees
pls8xx is offline   Reply With Quote
Old 07-27-2012, 03:53 PM   #8
JOATMON
ddawg16's Avatar
Angle of cut
Google is your friend....
http://en.wikipedia.org/wiki/Decagon
The angle depends on which reference you want. Internal angle is 144 deg.....or 36 deg from each point....(360 deg/10)
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
ddawg16 is online now   Reply With Quote
Crown molding angle question Lavid2002 Carpentry 35 08-24-2012 07:05 AM
Is It Okay To Hang A Sheet Of Drywall On An Angle? moondriver Drywall & Plaster 12 05-01-2009 04:22 PM
Tight drilling angle fw2007 Electrical 8 05-31-2008 10:33 AM
Staircase wainscoat angle DIYPRO Carpentry 5 04-08-2008 05:12 PM
Brick Veneer on steel angle iron sandyman720 Building & Construction 3 07-09-2007 09:21 PM
