Anderson Door Hardware - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-29-2011, 10:31 PM   #1
I am buying an Anderson storm door for my home, but they do not offer the bronze hardware. I have noticed that Pella does and sells just the replacement hardware. Would they be compatible?
Vnssa426 is offline   Reply With Quote
Old 10-30-2011, 09:20 AM   #2
Rewards Points: 5,330
You need to see what width door the hardware is made for.
You also need to know if the door you're buying has the holes for the hardware already drilled.
Some doors have mortised hardware, some surface mounted hardware.
An unholed door with surface mounted hardware will be fine to switch.
Mortised hardware will not work in an unmortised door.
Ron
B. Franklin 1759
Old 10-31-2011, 07:23 AM   #3
My Andersen catalog shows Oil Rubbed Bronze, Distressed bronze, and quite a few other metal and painted finishes.
Anderson vs. Pella Exterior French Doors Beth R Building & Construction 5 11-10-2010 06:45 AM
Anderson Casement Windows is it Worth Repairing? MCASEY328 Building & Construction 2 07-28-2010 09:25 PM
replace anderson windows hobbyguy2002 Remodeling 13 12-06-2009 10:34 PM
Typical Cost to Install Anderson 400 Windows jombres General DIY Discussions 1 10-16-2009 10:57 PM
Anderson Slider Doors Maralind Building & Construction 4 01-25-2009 09:15 PM
