Andersen Sliding Door - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-26-2009, 01:45 PM   #1
I have installed a new Andersen 400 series sliding door to a newly framed wall and noticed that with the nailing fins attached to the exterior 3/4 inch plywood sheathing, the interior of the door frame is flush with the wall studs not the drywall. Have I done something wrong? Do the nailing fines attach to the studs and then the plywood sheathing goes over them? I'm guessing I can use creative moulding to cover the difference between the door frame and drywall. Any suggestions?
jphelps is offline   Reply With Quote
Old 01-26-2009, 02:20 PM   #2
Most exterior plywood applications are only 7/16 or 1/2. All you need to do is add a jamb extension.
Josh Jaros
jaros bros. is offline   Reply With Quote
Old 01-26-2009, 02:30 PM   #3
the Musigician
DangerMouse's Avatar
amazing! imagine that.......... 3/4" plywood sheathing.......
whoda thunk it? -=chuckle=-
you installed it right, not your fault. but that's what i did to deal with the exact same thing, 6" walls + 3/4" PLYWOOD, + 1/2" drywall = custom moulding for me. =o)
but i'm creating all my own moulding/trim/jambs, etc. from walnut anyways, so it's just another step for me and my handy-dandy saws.
DM
Old 01-26-2009, 07:20 PM   #4
BUILDER / REMODELING CONT
buletbob's Avatar
Correct. you installed the door correctly. like the mouse stated 3/4" sheathing was on the house. Now you must install a 1/2" build out around the door frame. make sure you do not cover the top parting strip that holds the door in. and try and keep the sides the same distance away as you did the top. this will give the door the same reveal all away around the frame. plus no nails will go through the weather striping.
Good call guys. BOB
Andersen Double Hinged French Door Problem tconway Building & Construction 24 06-05-2016 07:30 PM
Replacing a HUGE sliding glass door w/ a hinged patio door. ZeroTX General DIY Discussions 12 05-02-2013 10:39 AM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 09:13 PM
