Originally Posted by hkwatcher
I also have a heavy divider I want to anchor, but mine will be anchored into a concrete wall. Do you think I need to build a frame for first or can we just use an impact drill with the plactic anchors and screws and go into the concrete with the hinges? (I plan to use 2)
unless you are trying for a certain look, there is no reason you can't simply anchor right to the concrete wall.
as for plastic anchors, there are some that are better than others, but over all they do a pretty good job for a light duty application in concrete.
At first I was thinking we could use a sort of piano hinge, but my husband says it would not be strong enough. Any opinions?
I can post pictures if necessary.
Piano hinge might be plenty strong, especially since it's only two panels, and doesn't sound like it will be opened and closed on a regular basis. there are other options, but hard to say for sure based on the limited info
Pictures are ALWAYS helpful!
