-   -   Anchoring fence posts (http://www.diychatroom.com/f14/anchoring-fence-posts-76954/)
Brandon17 07-24-2010 09:19 AM
What's available to anchor fence posts?
KennMacMoragh 07-24-2010 09:23 AM
A hole in the ground with concrete, usually two 60 lb bags per post is enough.
Brandon17 07-24-2010 09:31 AM
Thanks Kenn, I was wondering more towards anchors that keep the wood separate from concrete or soil.
concretemasonry 07-24-2010 11:05 AM
What kind of fence? - 6' privacy with a lot of wind, barbed wire or something in between?
Not much is available in the world of tin and steel unless you don't need much strength..
If you do not have width and depth, there will be movement that can continue.
The top foot or two of soil has little lateral strength, so the width is important. - It is hard to beat something rigid that is 8" wide. If you have the energy and time you can go deeper, but still need the rigidity.
Avoid the steel post that are really meant for realtor signs, since they are really nothing, just as realtors are (quick in and hopefully quick out).
Dick
Gary in WA 07-24-2010 01:45 PM
Simpson has a line of them. Hold you cursor over to view individual ones: http://www.strongtie.com/products/ca...bases_diy.html
Good to keep them away from concrete, the worst thing to do.
Be safe, Gary
concretemasonry 07-24-2010 03:46 PM
The Strongtie is OK, but for a 6' privacy fence there is not enough moment resistance in the connection to take advantage of the embedded material. OK for free standing decks if there is sufficient lateral strength in the structure and for open fencing systems to a limit. - For a substantial privacy wall they are not adequate from an engineering standpoint, unless no one is around in a strong wind.
vsheetz 07-25-2010 12:21 AM
I like to build wooden privacy fencing using metal posts set in concrete. The posts will last a long time (longer than the wooden facers and stringers) whereas usually wooden posts are the first thing to go bad. So next time you just replace the wood stringers and facers on the existing steel posts.
4just1don 07-25-2010 03:24 PM
daughters board fence gates dont stay locked
Five years down the fence age saga of life.
Her dog can open them and get out faster than I can walk in them. Cant take a pic, too far away. but this is what they are.
Hinge side of gate next to house. Latch on post 3-4 foot away,,then 4-5 foot of fence to corner where it right angles for dividing fence for side yard with neighbor.
Latch side flops around and unhooks at the least bump. Do you put a board over the top of the open gate to stiffen this up???And keep the spacing right?? think it wobbles in and out some too.
Or try some 2" water pipe 4' in concrete and ground and five foot up and bolt pipe and wood post together??
think this fence was done by midnite fence or us,,,and a standard were done and gone warranty
PWilcox 07-25-2010 07:59 PM
For the best looking wooden fence a post in concrete is the best choice for areas with ANY wind, otherwise if you have NO WIND you could do sand and pea-gravel. If you are worried about termites then a direct contact, pressure treated post would be needed. If you use any post to ground hardware, read the disclaimer about lateral loads (wind and earthquake) when used with fencing.
Paul
Orange County, CA
Wilcox Construction
4just1don 07-25-2010 10:45 PM
I thought my post above was supposed to be a new thread. Moderators can make it one if they can.
rickrgrs 03-22-2011 11:52 PM
Originally Posted by PWilcox (Post 475255)
If you are worried about termites then a direct contact, pressure treated post would be needed.Paul
Orange County, CA
Wilcox Construction
We just had a strong wind and rain storm here in So Cal that blew down 45' of 6' tall wooden privacy fence. The posts were pressure treated 4x4s set in concrete. The posts snapped off at the concrete because they were completely eaten up by subterranean termites! Earth to wood contact; Top soil covered the concrete and allowed the bugs to get in.
vsheetz 03-23-2011 01:17 AM
Yet another reason I like metal posts.
Marty1Mc 03-23-2011 07:25 AM
I built a 6' board on board privacy fence over 20 yrs ago. I used 6x6 treated posts in cement. The board on board design allows wind to get through. It is still straight after all this time.
epson 03-23-2011 08:46 AM
strongtie is what you want
http://ep.yimg.com/ca/I/yhst-9937170..._2147_35807150
http://ep.yimg.com/ca/I/yhst-9937170..._2147_35819213
