Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 05-05-2008, 09:01 PM   #1
Lightbulb
anchoring door in a brick and concrete wall
I am going to be removing 2 windows and installing a french door in place of the windows. I am renting a massonary saw to cut the brick on my house (my walls are brick, 4" of concrete and then another layer of brick with plaster direclty over the brick on the interior walls. The opening is the correct width with a good steel header over the windows I am just not sure how to attach the doors to the brick walls, any ideas??? Thanks.
agroux is offline   Reply With Quote
Old 05-08-2008, 01:28 AM   #2
Use a masonry bit and a hammer drill if possible.You may be able to use a regular drill with a sharp masonry bit and some effort. Drill into the mortar area between the brick. In the concrete area you can drill anywhere. Use tapcon concrete screws or red head brand anchors with stainless screws.
Fasten jambs and install door.Take your time.Take very good measurements.If opening is correct size for door plus jambs should be able to use pre-hung door.If opening is a little too wide you can always use cedar shims or even filler strips.Much more effort will be required if opening is too narrow.
http://www.handymanjimnoonan.com
Handyman Jim Noonan is offline   Reply With Quote
20 year old Brick Wall Repair Bobrobert General Discussion 15 11-22-2011 04:07 PM
creating a basement window opening in a brick wall amakarevic Building & Construction 5 01-30-2008 12:06 PM
brick foundation walls drummerjim Building & Construction 5 01-23-2008 06:23 AM
Forming concrete entry/porch... MLO Building & Construction 3 11-23-2007 12:26 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
