Aluminum Studs - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-10-2009, 10:09 PM   #1
aluminum studs
I wanted to re-insulate and install new sheeting on a florida room that has been converted into a bed room , the rooms insulation is so bad the air runs in the summer all day and heat in the winter. I found aluminum studs in the wall would this be a problem or would this be nothing to worry about, also would there be any down side to combine wood studs to eleminate some windows and relocate a door. thanks
fishin dude is offline   Reply With Quote
Old 02-10-2009, 10:14 PM   #2
Registered User
Termite's Avatar
You probably found steel studs...
You can leave them with no concern, or can add to the wall with new steel studs or wood. Combining the two side by side is certainly possible if the right fasteners are used.
Aluminum studs ? - How to Mount TV to? Seminole Home Theater 6 12-11-2008 08:51 PM
Framing a basement w/ aluminum studs doiturselfguy Building & Construction 10 08-07-2008 07:54 AM
Stud mounting on Aluminum studs DK75 General DIY Discussions 2 02-17-2006 08:24 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
