Alternative To 2x16d For Top Plate To Stud Connection? - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-17-2013, 03:14 PM   #1
Rewards Points: 89
Alternative to 2x16d for Top Plate to Stud connection?
For an existing roofed and screened porch, I converted the space into a mudroom and bathroom.
I built the exterior walls in-place, meaning I didn't build the wall flat on the floor, then tip it up. Instead, I nailed the top and bottom plates to the existing structure, then measured and cut the vertical studs to fit.
Now, I read the nailing schedule and I see that the top plates to studs should have been end-nailed with two 16d nails. Instead, I toe-nailed six 8d nails top and bottom (2x6 construction).
I am concerned I will fail my framing inspection. Does the code allow toe-nailing in this case? I am in NY state.
toddmanqa is offline   Reply With Quote
Old 06-17-2013, 04:46 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
a quick call to the building department would answer that question as it does not matter what our opinion is, it's the building officials that does.
with that said Table R602.3(1) of the 2009 International Residential Code (your code may differ) states that stud to sole plate can use (3)8d or (2)16d toe-nails, top plate to be end nailed into stud with (2)16d.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 06-17-2013, 04:48 PM   #3
GBrackins's Avatar
I am not sure what the difference is in the NY code and the IRC is. here is a link to the IRC nailing schedule
http://publicecodes.cyberregs.com/ic...9_6_sec002.htm
Gary
Old 06-17-2013, 04:49 PM   #4
GBrackins's Avatar
here is a link for the 2010 NY Residential Code nailing requirements
http://publicecodes.cyberregs.com/st...-P-2010-999999
Gary
ground wire to ground plate connection? Sailhighc Electrical 4 09-05-2012 10:46 AM
Tray Ceiling / Soffit - Stud connection help needed mindshot Building & Construction 0 01-10-2010 04:58 PM
Ceiling Box Cover Plate Alternative atw58 Electrical 1 09-13-2009 09:21 PM
rotted sill plate, joist ends and stud bottoms oh my. slowjo Building & Construction 16 05-02-2009 09:43 PM
Interior Wall Stud Joist Connection Issues. Brandnewruins Carpentry 5 04-22-2009 11:46 PM
