Ajustable Shelving Jig - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-26-2012, 03:56 PM   #1
CrossWorks's Avatar
Rewards Points: 150
Ajustable shelving jig
As I'm googling for this jig, I got to thinking I better ask the the guys at DIY their thoughts.
Is their one you recommend "that is NOT plastic please"!
A great personality will open many doors in life,
but it's your character that keeps them open!
www.crossworksme.com
"Where Every Nail Has a Purpose!"
CrossWorks is offline   Reply With Quote
Old 11-26-2012, 04:35 PM   #2
Rewards Points: 2,212
1/4" peg board, cut to the width and height you want
mae-ling is offline   Reply With Quote
Old 11-26-2012, 05:26 PM   #3
DIY staff
Rewards Points: 7,174
I buy a predrilled melamine shelf side---slice it up into handy sizes and use that as my template---when the holes get to worn--I chuck it and grab a new one.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
funfool (11-26-2012), kwikfishron (11-26-2012)
Old 11-26-2012, 05:31 PM   #4
CrossWorks's Avatar
Rewards Points: 150
Both suggestions may be good for a workshop. However in this case it's cabinet grade birch plywood and the quality level needs to be high.
But thanks for your input nonetheless.
Old 11-26-2012, 05:56 PM   #5
That's what we used in the shop for quality cabinets. Your drill bits are what matter.
Old 11-26-2012, 06:04 PM   #6
Rewards Points: 14,312
Unless your planing on making a hundred cabinets what's been suggest will work fine.
Old 11-26-2012, 06:15 PM   #7
funfool's Avatar
Rewards Points: 534
Great ideas, will remember them next time needed.
Seems just need to control the depth so do not go to far.
Could use some tape on the drill bit as a guide ... maybe a wooden block the right depth.
funfool is offline   Reply With Quote
Old 11-26-2012, 06:33 PM   #8
A simple lock collar works good.
http://www.ebay.com/itm/7-pc-Drill-B...item19d510f899
mae-ling (11-27-2012)
Old 11-26-2012, 06:38 PM   #9
Stairguy
Millertyme's Avatar
Rewards Points: 508
I use the plastic one from rockler. I have drilled hundreds of holes with it and have never had a problem.
Millertyme is offline   Reply With Quote
Old 11-26-2012, 09:40 PM   #10
chitownken's Avatar
Rewards Points: 510
I also use the Rockler kit. It's the self centering bit that kames it work well. Brad point bit in collar that makes clean holes and does not ever touch the jig so the holes don't get widened out. Like Millertyme, have done hundreds of holes with no issues.
chitownken is offline   Reply With Quote
Old 11-27-2012, 04:58 AM   #11
CrossWorks's Avatar
Rewards Points: 150
Well that's good to know. Thanks Millertime, Chito. I was about to plunge into this beast: http://tinyurl.com/d5d5bwe
Boy was I liking that toy, but you all know as well as I that these days, liking something to much does not justify spending the money. [need I say iPad!]
Rockler is just down the road from the current job to boot. So another lunch time errand.
Thank you all for your points of view.
Wood Closet Shelving Kits ? Chemist1961 Carpentry 3 12-11-2011 12:49 PM
How to make recessed shelving DesignDuoBlog How To Guides 0 08-30-2011 04:20 PM
no beam shelving Goodcrieff Interior Decorating 0 01-18-2011 08:49 AM
Garage shelving ideas koodawg General DIY Discussions 3 12-31-2010 09:52 AM
"Built In" shelving Missy Carpentry 8 04-21-2008 05:50 PM
