-   -   Ajustable shelving jig (http://www.diychatroom.com/f14/ajustable-shelving-jig-164799/)
CrossWorks 11-26-2012 03:56 PM
As I'm googling for this jig, I got to thinking I better ask the the guys at DIY their thoughts.
Is their one you recommend "that is NOT plastic please"!
mae-ling 11-26-2012 04:35 PM
1/4" peg board, cut to the width and height you want
oh'mike 11-26-2012 05:26 PM
I buy a predrilled melamine shelf side---slice it up into handy sizes and use that as my template---when the holes get to worn--I chuck it and grab a new one.
CrossWorks 11-26-2012 05:31 PM
Both suggestions may be good for a workshop. However in this case it's cabinet grade birch plywood and the quality level needs to be high.
But thanks for your input nonetheless.
mae-ling 11-26-2012 05:56 PM
That's what we used in the shop for quality cabinets. Your drill bits are what matter.
joecaption 11-26-2012 06:04 PM
Unless your planing on making a hundred cabinets what's been suggest will work fine.
funfool 11-26-2012 06:15 PM
Great ideas, will remember them next time needed.
Seems just need to control the depth so do not go to far.
Could use some tape on the drill bit as a guide ... maybe a wooden block the right depth.
joecaption 11-26-2012 06:33 PM
A simple lock collar works good.
http://www.ebay.com/itm/7-pc-Drill-B...item19d510f899
Millertyme 11-26-2012 06:38 PM
I use the plastic one from rockler. I have drilled hundreds of holes with it and have never had a problem.
chitownken 11-26-2012 09:40 PM
I also use the Rockler kit. It's the self centering bit that kames it work well. Brad point bit in collar that makes clean holes and does not ever touch the jig so the holes don't get widened out. Like Millertyme, have done hundreds of holes with no issues.
CrossWorks 11-27-2012 04:58 AM
Well that's good to know. Thanks Millertime, Chito. I was about to plunge into this beast: http://tinyurl.com/d5d5bwe
Boy was I liking that toy, but you all know as well as I that these days, liking something to much does not justify spending the money.:whistling2: [need I say iPad!]
Rockler is just down the road from the current job to boot. So another lunch time errand.
Thank you all for your points of view. :thumbup:
