Advice On Staircase Renovation Issue - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-04-2011, 05:42 PM   #1
Advice on staircase renovation issue
removed carpenting from staircase and was happy to find hardwood treads underneath. however all 13 steps have 3 large nails on the tread surface. Some of the treads have a nail that is bent over and not sitting flush with the surface. pics are attached to show the issue. 9 of the 13 steps are boxed in on both sides and sitting in a groove on the stringer so I am not really sure if the nails are serving much of a purpose. how would one go about correcting this? if it is a matter of pulling the nails out how can i do this so as to not damage the tread surface?
Advice on staircase renovation issue-img_0522.jpg   Advice on staircase renovation issue-img_0523.jpg
frankleibo is offline   Reply With Quote
Old 06-04-2011, 07:27 PM   #2
timthetoolman
Hmmmm? Any tool used to remove these nails in my arsenal would cause more damage than necessary...on their way out, they like to chip the surface further. In your situation, it sounds like they serve no purpose. Just pound them below the surface with a nail set and wood fill over. That's prob gonna be your best bet.
timthetoolman is offline   Reply With Quote
The Following User Says Thank You to timthetoolman For This Useful Post:
frankleibo (06-04-2011)
Old 06-04-2011, 08:28 PM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 190
For the nails with the head showing only, you can use a drill bit the size of the nail shank, or just a hair larger, and drill the head of the nail off then set the rest of the nail deeper and fill. For the nails bent over you will have to get something under the bent nail so you can get hold of it with a hammer. Place a piece of 1/4 plywood or some other wood under the hammer so it doesn't mar your tread. Pull the nail and fill the hole. If the treads are oak chances are you will not be able to pull the nail. If you cannot pull the nail, bend the nail back and forth until the nail breaks then set it below the surface and fill.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
Old 06-04-2011, 09:50 PM   #4
Too Short? Cut it Again!
You may want something thinner and flatter than the nail pulling side of a hammer. I would try a the edge of a strong flat bar. You will still need a shim, wedge or something under to leverage again or you will dig into the tread.
Looks a little weird but if those nails are the only thing anchoring the treads to the stringer you don't want to eliminate them?
You sure that is a hardwood by the way?
Old 06-04-2011, 10:12 PM   #5
Treads are oak, risers are pine. Nails aren't the only thing holding treads in place but am going to follow jiju's advice. Thanks all.
Flood/Drainage Issue On Garage Man Door altc81 Building & Construction 2 04-17-2011 09:19 AM
Basement Renovation Planning: Help! navi_jen Plumbing 0 06-16-2010 10:41 AM
Comfortmaker furnace issue: advice on how to proceed? bill_b HVAC 5 11-09-2009 09:29 AM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 04:49 PM
Converting an open staircase to a "closed" staircase? tony1853 Building & Construction 7 01-05-2009 02:55 PM
