Advice On Repairing Rim Joist - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-21-2011, 07:48 PM   #1
Advice on repairing rim joist
What started out as a simple Sunday project of replacing some risers and treads on the stairs of my lower unit of my duplex has quickly escalated. As some background info the house was built in 1893 and has been rather poorly maintained. The last few owners have been investors that could have given two sh*ts. So here we stand. I had to lay concrete for the stringers to sit on, and plan on securing them to the concrete using a 2x12 secured into the concrete and then attaching the stringers to the 2x12 from the side. Where my big problem lies is that the rim joist(s) and I use plural because there were basically 2, one rotted piece of wood secured to the original very rotted piece of wood, need to be replaced. The joists themselves are a bit rotted as well, although not terrible. I am wondering if am able to replace the rim joists and get them secured (even partly th the brick if needed) if that will be sufficient to have the stringers hung. Whew...sorry for the long winded explanation, and I will try to get pictures up tomorrow. Any help is appreciated!
dukes32 is offline   Reply With Quote
Old 04-21-2011, 09:07 PM   #2
Rewards Points: 5,336
Photos will help with the visual.
You mention attaching wood to concrete. You should isolate the contact between the two. Wood against concrete will cause the wood to absorb moisture and speed up the rottting process.
Ron
Old 04-22-2011, 12:44 PM   #3
Here are some pictures of what I am working with. I have already taken off the two rim joists that were poorly attached. I am thinking if I attach a new rim joist from a PT 2x6, I can then attach my stringers to that. Any thoughts/hep would be appreciated. I am trying NOT to have to redo the whole deck. As you can see already there is a slight slope on it, but this is a rental and while I am trying to take as best of care as possible, this project was something I did not anticipate and certainly did not budget for.
Old 04-22-2011, 03:10 PM   #4
To add to what Ron said, you do not want wood in direct contact with concrete. The pictures show that to be the case which was deffinately a main culprit to the rot. If you have access under the deck, build a temp wall under the joists to support the weight of the deck, and then cut out and replace the rim joist with flashing as a moisture barrier. If the wood is truly that rotted, then you may not need the temp wall because it's not supporting the deck anyway. Good luck.
Rick
http://myhandyadvice.blogspot.com/
sharpsport is offline   Reply With Quote
Old 04-22-2011, 03:44 PM   #5
kwikfishron's Avatar
Rewards Points: 576
My guess is there is more than a rotted rim to deal with.
Is there a roof over that, what’s that white post supporting?
kwikfishron is online now   Reply With Quote
Old 04-22-2011, 03:57 PM   #6
Thanks, I think my plan of attack is going to be to attach new rim joists tomorrow, w/flashing as a moisture barrier to the existing joists. From there I am going to attach the joist hangers to support the stringers. we will see how things go. I'll post pictures if I ever get this figured out.
Old 04-22-2011, 03:58 PM   #7
The post is supporting the roof thats over the deck area. Love houses that were built 130 years ago...
Old 04-22-2011, 03:59 PM   #8
And yes.... I am almost certain there is more than just a rotted rim.....which is what I am kind afraid of.
Old 04-22-2011, 04:06 PM   #9
Rewards Points: 576
How about a picture standing back showing the roof also.
You can see an obvious drop at that post. It looks like the roof needs to be supported and jacked up.
I’d re-think your plan for tomorrow.
Old 04-22-2011, 04:19 PM   #10
Here are two pictures from a bit back, and then an up close shot of where the roof support is attached to the deck. I think one can see why the deck is sagging....
Old 04-22-2011, 04:36 PM   #11
Rewards Points: 576
It just keeps getting better, now the post is supporting the second story and a roof.
You have some serious structural issues there. If you could not see this from the start then it’s not DIY, call a pro.
Old 04-22-2011, 04:45 PM   #12
Yes, I believe you are correct. My DIY for exteriors stops at stringers and treads. What do you think my plan of attack should be? And I very much appreciate all of this help.
Old 04-22-2011, 05:08 PM   #13
Since I have access to under the deck/porch area, how practical would it be to use a screw jack under that corner to support it?
Old 04-22-2011, 05:49 PM   #14
I would think the weight of the second story and roof has dropped that whole corner.
I would work from the top down, not from the bottom up if that were the case.
Check out the flooring in the room above the porch to confirm my observation. If it's bad, the floor will slope to the corner.
If that's the case, I would jack up the second story to take the weight off the post and porch.
I'd then strip the decking off the porch to get a look at the framing.
Reframe the support structure and re-deck the porch.
Take the post out and check it's condition.
Replace if necessary.
Ron
Old 04-22-2011, 06:04 PM   #15
Rewards Points: 576
Add foundation repair to the list. That corner has had issues for a long time
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 12:30 PM
Need advice - repairing cracked garage foundation beerdog General DIY Discussions 3 09-26-2009 01:16 PM
Space between joist and beam on deck schveiguy Building & Construction 11 09-08-2009 09:15 AM
one rotted deck joist to replace, need advice dougq Building & Construction 10 07-07-2009 02:18 PM
Crawl Space Beam and Joist Support Questions Fire4Effect Building & Construction 5 06-28-2009 01:07 PM
