Adjusting Metal Pre Hung Garden Door - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-14-2009, 04:49 PM   #1
adjusting metal pre hung garden door
We are moving into a new to us home. From the great room there is a pre hung garden door. It consists of a normal metal framed door and beside it a large ( door size) crank out window. The door and window are in one frame. Both the door and window are rubbing against the frame when you close them. It almost appears that someone put in a shim that was too large and it is pushing against the frame of the door. We have not taken posession yet but I ant to be ready to fix that problem. I have had doors that rubbed before and I was lucky enough to just put in a few extra long screws from the frame into a stud and pull the frame away from the door. I do not think that will work this time. Would I have to remove the whole setup and reinstall?? Any ideas??
Moisheh
moisheh is offline   Reply With Quote
Old 09-15-2009, 10:00 AM   #2
Rewards Points: 5,332
What you need to do to fix the issue will depend upon what's causing it. When you get into the house, you will need to open up the spaces on the door sides to establish a resolution.
Ron
Replace door sill = Need new door? NNJGUY Carpentry 23 09-01-2009 01:54 PM
Pre-hung door with metal studs gmainolfi Building & Construction 4 02-07-2009 08:42 PM
adjusting size of screen door? darsunt Building & Construction 1 11-11-2008 07:11 AM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 02:09 PM
Adjusting My Garage Door Opener's UPWARD Travel cbenard Electrical 11 12-04-2005 12:24 PM
