Adjusting Height On Old Dining Room Table - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-14-2009, 12:46 PM   #1
Adjusting height on old dining room table
Hey guys, I'm a total novice here hoping someone can give me some advice.
Wife just bought an old antique dining room table, but we've realized it's probably about an inch too low for our current chairs. So we bought some castors to install on the legs to raise it slightly. Only problem is we didn't check the bottom first and have now discovered these circle metal raiser-thingys (yes, I'm a novice) already installed on the bottom. THey seem very firmly attached....we can't tell whether they're screwed in or glued.
So not sure what to do.....try and find a way to remove the metal raiser....or jsut shave off an inch or two and reinstall some sort of wood extension to the bottom, or??? See attached pic.
I really just want to get rid of the thing at this point, but my wife loves it...
hex27 is offline   Reply With Quote
Old 06-14-2009, 02:43 PM   #2
You should be able to just pry the "metal raiser-thingys" off. Just tap a srewdriver end under the edge and pry.
hayewe farm is offline   Reply With Quote
Old 06-14-2009, 07:49 PM   #3
Old School
Willie T's Avatar
I think the technical name is "ROUND metal raiser-thingys".
Willie T
Old 06-14-2009, 09:53 PM   #4
If a button is sunk deep into the wood and you can’t pry it out, drill a 1/4-in. hole and lever it out with a small screwdriver.
http://www.rd.com/45124/article45124.html
hiding that ugly 2x12 beam in new dining room DangerMouse Project Showcase 9 01-10-2011 10:03 AM
dining room table TBS Painting 2 11-06-2008 12:48 PM
Looking for Japanese dining room table plans dantefontana Carpentry 3 03-01-2008 08:11 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
