Adhering Plywood To Metal Wall - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-13-2014, 03:23 PM   #16
Rewards Points: 87
Originally Posted by sublime2 View Post
Op, indicated the sets are NOT flat screen but older televisions.
So weight is definitely a concern.
Sorry they are flat TV's but just a few years old so they aren't as thin and light as newer models. By design though they are flat screen, LCD TV's (32") though not as slim and light as the ones coming out in the last 2-3 years.
ssgtjoenunez is offline   Reply With Quote
Old 01-13-2014, 08:33 PM   #17
Registered User
Rewards Points: 4,924
Might give a call to your commercial insurance carrier for any requirements; licensed welder/general contractor with bond/liability insurance before you rush out a buy a welder...
Gary
Old 01-14-2014, 01:54 PM   #18
Rewards Points: 87
I spent some time yesterday dry fitting the TV into the box and then weighing the entire enclosure. Provided I use long enough self tapping metal screws, I wont have to penetrate the exterior wall of the building and weld the nuts on. The box itself is not as heavy as originally anticipated and has enough surface area in the back for me to sink as many self tappers as I need to feel comfortable - 7 of which will hold the actual TV to the box and wall.
This will be much easier and ultimately make the install faster.
Old 01-14-2014, 05:21 PM   #19
DIY staff
Rewards Points: 7,174
If you add some PL Premium adhesive before you use the self tapping screws-(TEC Screws) you will be good---the plywood will need to be chiseled off when the time comes.
Old 01-21-2014, 11:07 AM   #20
Rewards Points: 87
I went ahead and mounted my box to the metal wall using self tapping screws. It worked great! Here's a final picture showing the end result and one of how I adhered it.
Adhering plywood to metal wall-image-1968843982.jpg   Adhering plywood to metal wall-image-1306113659.jpg
The Following 2 Users Say Thank You to ssgtjoenunez For This Useful Post:
bbo (01-21-2014), gregzoll (01-21-2014)
Old 01-21-2014, 02:46 PM   #21
chitownken's Avatar
Rewards Points: 510
Looks good!
chitownken is offline   Reply With Quote
Re: old buildings RWolff Building & Construction 157 01-19-2014 01:35 AM
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
Can I remove this wall? limited60 Remodeling 9 06-05-2012 02:32 AM
what is the angled sheet metal in front of my wall registers? aboynamedmoose HVAC 3 01-29-2012 10:39 PM
Drilled into metal in wall, now drill bit is magnetized... rehabhell Carpentry 16 02-18-2010 10:07 PM
