Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-27-2012, 11:27 AM   #1
Coconut Pete's paella!
CoconutPete's Avatar
Adding sliding glass doors to built-in shelves?
Is this a project I want to steer clear of?
My daughter is starting to crawl and I'd like to put the cable box, receiver etc. on the built-ins and put some doors on there to keep her from "helping herself" if you know what I mean.
CoconutPete is offline   Reply With Quote
Old 11-27-2012, 12:07 PM   #2
Stuck in the 70's
Blondesense's Avatar
Do you have a pic of what you're starting with?
Old 11-27-2012, 12:19 PM   #3
I'll grab one at home later. Think very plain though - basically a perfect square w/ movable shelves.
Old 11-27-2012, 12:34 PM   #4
memarybe's Avatar
Having raised seven children the youngest now 12, I will offer up a few words of wisdom on this subject.
Children and any type of glass do not go well together.....ever......period.
Use wood for the doors.
But eventually they learn how to open those too!
Best bet is too just raise the items up about 7ft. from the floor. Good luck!! And welcome to parenthood !!!
memarybe is offline   Reply With Quote
Old 11-27-2012, 07:13 PM   #5
sdsester's Avatar
You will probably have to take the units apart to cut the dado grooves for the doors to slide in.
Nice hinged cabinet doors would be a better option.
sdsester is online now   Reply With Quote
The Following User Says Thank You to sdsester For This Useful Post:
mae-ling (11-27-2012)
Old 11-27-2012, 08:14 PM   #6
An old Tradesmen
Moved to Carpentry.
Old 11-27-2012, 08:40 PM   #7
frame out a door like you would frame out a picture frame and use acrylic instead of glass, then you just have to use a few hinges.
add some trim to the rest of the piece to tie in the new doors
redman88 is offline   Reply With Quote
Replacing a HUGE sliding glass door w/ a hinged patio door. ZeroTX General Discussion 12 05-02-2013 11:39 AM
"Defogging" double-pane windows .... a gimmick?? alexz General Discussion 133 03-10-2010 01:35 PM
How to: Measure Patio Sliding doors SunGawd Building & Construction 6 06-09-2009 10:06 PM
Custom built legs for very large glass tabletop joeyboy Project Showcase 8 10-06-2008 11:48 PM
Painting Vinyl Sliding Glass Doors IdahoBob Painting 5 01-05-2008 05:34 PM
