Adding A Second Floor To A Garage - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-14-2010, 06:44 PM   #1
adding a second floor to a garage
We have a manufactured home on a slab and an attached garage to it, the garage has a 8" floating slab and 2x4 construction we want to add a second floor to this garage, the garage is 16'wx30'deep, the 16' side is attached to the home as far as i can tell, we live in Minnesota and have had no issues with either one of the buildings moving due to frost, any help would be appreciated.
h1100 is offline   Reply With Quote
Old 03-14-2010, 07:07 PM   #2
Civil Engineer
Rewards Points: 4,762
Normally adding above a garage requires a building permit, so the first place to start is with your local code enforcement official. Beyond that, you need a design for the project, which could be obtained from a standard book on framing. You will need to determine if your foundation is adequate to support a second story, the code official may be able to help, else you may need an engineer or architect to help out.
If you are planning on creating living space above a garage, there are lots of issues like exhaust fumes, fire protection etc., no doubt the code official will steer you in the right direction.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
h1100 (03-14-2010)
adding on to an existing detached garage ebstein Building & Construction 4 09-24-2009 10:32 PM
Adding A Garage kmb997 Building & Construction 4 07-17-2009 03:28 PM
Adding Service to Attached Garage SyracuseSteve Electrical 13 03-23-2009 12:20 PM
Adding on to house to build a garage. Ohioguy Building & Construction 5 02-09-2008 04:44 AM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 02:53 PM
