Adding On Porch Rails - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-18-2010, 12:05 AM   #1
adding on porch rails
I want to attach a rail siding around my back porch. I know everything to do except how do I attach the 2 by 4 to the outside of my house which is brick. how do you keep the screw to stay in the wall.Please help.have to do it myself no extra money to pay expert.
vacrafty is offline   Reply With Quote
Old 05-18-2010, 06:56 AM   #2
Tapcons screws work well in brick/concrete. You must use the proper size drill bit for the fastener, and it helps if you have a hammer drill.
Old 05-18-2010, 09:20 AM   #3
I also like tapcon screws into masonry.
oberkc is offline   Reply With Quote
Old 05-24-2010, 05:08 PM   #4
Thanks Bill,
I don't have a hammer drill just a regular heavy duty drill. Can I use that without going to the expense of renting one? I appreciate the information.Vickie
Old 05-25-2010, 01:03 AM   #5
drilling through brick
use a masonry bit with standard drill and go through mortar instead of tapcons use leaded rawl plugs and stainless steel panhead screws
mark2007 is offline   Reply With Quote
Old 05-30-2010, 02:59 PM   #6
All my working life, I used a standard drill with masonry bits, as hammer drills hadn't been invented yet!
It just takes longer!
At my last house, they fastened a vertical 2X6 to the wall first and then fastened the top and bottom rails to this!
Adding Gable porch in NNY webweever Roofing/Siding 0 04-18-2010 08:27 PM
adding a deck to existing concrete porch idiotbox37 Carpentry 6 12-02-2009 08:48 PM
Adding new Front Porch, need opinions MeraleeCrowl Remodeling 1 11-05-2008 01:47 PM
Color opinion for front porch rails and pillars? Beth777 Painting 6 07-14-2008 12:14 PM
Ideas for adding porch roof...pics! jcrack_corn Roofing/Siding 4 06-22-2008 12:30 AM
