Adding Pegboard To A Garage - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-13-2013, 09:01 PM   #1
Adding Pegboard to a garage
I have drywall in my garage, Iím planning to put in pegboard to get some storage. Should I remove the drywall and mount the pegboard to the studs or just put in furring strips and mount the pegboard to that?
JackLantern is offline   Reply With Quote
Old 05-13-2013, 09:09 PM   #2
Rewards Points: 13,732
If you remove the drywall the garage would no longer meet fires codes.
Add some stips, 2 X 2's are cheap and take up less area where it would stop the pegs from going in.
Make sure to add some across the top and bottom first then the stips in between.
Old 05-14-2013, 08:43 PM   #3
okay, thanks..i can just go over the top.
Old 05-14-2013, 10:07 PM   #4
Rewards Points: 744
I believe we used 1x2 at my buddy's place, though I can't recall for sure.
Seattle2k is offline   Reply With Quote
adding on a garage debd Building & Construction 12 11-16-2011 02:03 PM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Adding Circuits to attached garage john8791 Electrical 1 02-10-2011 01:55 AM
Insulating garage / adding attic Red Squirrel Building & Construction 4 04-19-2010 07:33 PM
Adding on to house to build a garage. Ohioguy Building & Construction 5 02-09-2008 04:44 AM
