Adding A Peephole - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-20-2006, 12:29 PM   #1
Adding a peephole
I live in a condo with a normal metal front door on it just like everyone else's. The odd thing is that our front doors do not have peep holes. I just want to add one for security reasons, as I don't like my girlfriend answering the door when she doesn't know who it is.
How hard is it to add a peephole to one of those doors? Is it just a matter of drilling a hole through and then snapping a peephole in?
Thanks in advance for any suggestions!
ChrisF79 is offline   Reply With Quote
Old 09-20-2006, 01:21 PM   #2
I did it on our front door to our house. It had a white styrofoam core. I just drilled the size hole it specified in the directions. It comes in 2 parts. one part slips through the hole, the other part screws into the first from the other side. Hope this helps.
biikman is offline   Reply With Quote
Old 09-21-2006, 01:17 AM   #3
I blame ProWallGuy
Rewards Points: 150
Chris, you can add a standard peephole, but I really like this one. Big wide angle and you can see 'through' it from a good distance away. You cannot see through them at all from outside.
Door Scope
Do a Google search and you'll find lots of folks selling them online. Your local locksmith might stock them.
Double A is offline   Reply With Quote
Old 09-22-2006, 10:53 AM   #4
Automotive Enthusiast
Sellncars's Avatar
Send a message via AIM to Sellncars Send a message via Yahoo to Sellncars
Hello there,
You can also go high tech and install a camera. This way she wouldn't even have to gett up to look. They are reasonably inexpensive, if you go to Sams Club they had them for $39.95 i do believe, and they work great for day and night, it also has an audio feature. Hooks right up to your computer or tv set.
Good luck,
Sellncars
Sellncars is offline   Reply With Quote
adding a wall cjay Building & Construction 5 09-11-2006 06:52 AM
Adding granules to smooth modified bitumen KCnorthernCA Roofing/Siding 7 06-22-2006 05:25 PM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 10:05 PM
adding a second floor chubdo Building & Construction 11 04-16-2005 12:20 AM
Adding a light cosumrz Electrical 8 12-16-2004 12:15 PM
