Adding New Stair Treads Question - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-24-2014, 12:03 AM   #1
iminaquagmire's Avatar
Rewards Points: 338
Adding new stair treads question
I've been asked by a family member to redo a set of stairs for her, adding new treads and molding. What had existed was a set of prefabbed housed stringers with 2x12 treads that then had pergo and nosing glued on top. After ripping off the pergo due to an extensive mold remediation, I'm left with the 2x12's and 3x4 ply risers. As you can see in the pics, there are lots of gaps and leftover glue present. I'll be going over it all with 5/4 pine veneer treads, leaving the existing risers.
My plan was to scrape off all the old loose glue and filler they put in prior to the pergo and put in a smooth coat of latex patching compound or some Durhams rock hard depending on what I find under all the glue. Then a full bed of PL premium. I have access to all but the bottom step and will screw the treads in place, removing the front ones after the glue sets so as not to create an expansion/contraction problem.
My concern is the glue. The treads are just at 10" and are veneered smaller pieces so I'm pretty confident that wood movement is not an issue. But I'm just wondering if PL premium has any give to it or if it will be too hard and crack loose with wood movement on one end of the spectrum or if will be so rigid that it won't allow the wood to move.
As I usually do, I'm probably over complicating things, but I just wanted to see if anybody had any insight on this.
iminaquagmire is offline   Reply With Quote
Old 02-24-2014, 12:24 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 304
One main concern would be any difference in height after adding the 5/4 treads. The stairs must be in code for insurance to pay off in case of a fall, if out of code they won't pay.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 02-24-2014, 12:54 AM   #3
Rewards Points: 338
The difference in height is negligible. First thing I measured. They still fall within code. It will actually be better since the previous owners added backerboard and tile to the top landing.
Old 02-24-2014, 07:32 AM   #4
MarginallyQualified
Rewards Points: 2,464
That sounds like an awful lot of work from here.
Prefabbed stair treads with nose.
Remove the old set the new.
Replace the risers at the same time if warranted.
They don't have to be fancy.
The Following User Says Thank You to TarheelTerp For This Useful Post:
woodworkbykirk (02-24-2014)
Stair tiling question... avro1 Flooring 1 03-27-2013 11:01 AM
Stair Riser question CharlieR Flooring 1 02-24-2013 01:09 PM
Question regarding gap between stair tread and skirt Awachter Carpentry 8 09-21-2012 09:06 AM
2x12 redwood stair treads cracking in center JimmyRrichards Carpentry 4 08-10-2011 10:29 AM
Sanding my stairs. Wrong equipment? Question about removing treads. Kinda long, sorry Mike in Arkansas Flooring 3 04-23-2009 01:04 PM
