Adding Exterior Insulation Foam - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-16-2011, 11:20 PM   #1
Adding exterior insulation foam
We've recently installed new windows but did not block the windows out to make room for exterior foam if we ever want to add it to the exterior of our home under new siding. Is there a way to finish the new siding to the window without adding to the brick mold of the window?
Finclyde is offline   Reply With Quote
Old 12-16-2011, 11:33 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
I don't understand what "block the windows out for foamboard" means. "without adding to the brick mold".
Are these 2 separate questions, or...?
Or do you mean there's not enough room to tuck foamboard and siding behind the molding?
You mean the window went under the foam and now you can't tuck the siding?
I think that's what you mean.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 12-17-2011, 10:33 AM   #3
The outside edge of the window brick mold is currently flush with my existing siding. I'm thinking about pulling my siding, adding exterior foam blocks to add to the r value of the home and then putting vinyl siding on to finish. But now, because the foam adds to thickness of my siding, the new vinyl siding will stick out from my window by about 3/4 in. I am looking for an idea on how to finish my window to make it flush with the new siding without adding 3/4 in of material to my brick mold.
Old 12-17-2011, 10:48 AM   #4
Disabled wood vet
titanoman's Avatar
You really need to pull the window and install it over the foam. This shouldn't be too difficult once the old siding is off
And do this on a warm day so as not to crack to vinyl fin during removal.
And of course you will have a little work inside to refinish.
Old 12-17-2011, 04:23 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
as mentioned you either have to pull the windows. or do a trim detail around the windows so the siding has something finish up to. the cheapest method would be to nail 2x4 around the perimeter then clad it with aluminum
woodworkbykirk is online now   Reply With Quote
Old 12-17-2011, 10:35 PM   #6
Great thanks guys
Adding foam board insulation & plywood to underside of roof sheslostcontrol Insulation 1 05-04-2011 08:08 PM
Adding batt insulation to foam for increased R value Mike Mike Building & Construction 3 02-22-2011 01:55 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
adding foam bd insulation to attic wall (fire code) park9472 Building & Construction 0 04-14-2010 03:17 PM
Adding Foam Board to Exterior Wall Cavity Earnie Building & Construction 3 02-24-2010 02:11 PM
