Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-07-2009, 11:36 PM   #1
Default Add divider without attaching it to walls
I need to make a divider to close off the kitchen. I want to make it without attaching it to the walls so that I can take it down without any damage. I was thinking of some kind of expander device, like those curtain rods that twist. The 2 openings are a doorway, and about an 8x8 opening. I want a door in both openings. I was thinking of making a frame out of 2x2s, and diagonal cross pieces like under a porch, so you can see through it. Any suggestions?
Redgreen is offline   Reply With Quote
Old 11-08-2009, 01:31 AM   #2
We pick these?
Doors that open and close won't do well in walls that aren't fastened at the top and bottom.
NailedIt is offline   Reply With Quote
Old 11-10-2009, 08:46 AM   #3
add-divider-without-attaching-walls-door-spreader.jpgattach rubber cabinet door bumpers to the outside of the 2x2 frame, and attach an accordion door to the bottom of the spreader. The spreader will have to be tight fitting, so the door doesn't fall out. You may even want to use cam latches to hold the spreader in place. It won't be readily removable, but if you are renting, and want something to remove when you move out, this will work pretty good.
CustomBuild is offline   Reply With Quote
More On This Topic
How To Brace A Doorway
How To Brace A Doorway by Expert Village
This is Ben Ingham with Expert Village talking about a walk out basement. It is just the way to get the border in place and get the block tap into the place in a way to clean out the joints so you have to have a little trowel when that is all over with... Read More »
My name is Tres Tew; I am an instructor here at Yu Shasasru Martial Arts. On behalf of Expert Village, I'm going to be showing you how to defend yourself with open hands against either rifles or shotguns. Now surprise can be a very key component when... Read More »
Get creative with Legos and build a motorcycle. Legos are an excellent way to spend quality time with your child cultivating their imagination. The possibilities are endless with Legos. Use the tips below to make a basic motorcycle, and then tweak it... Read More »
You can choose many different sizes and styles of glass block for decorating. The block comes in 4- to 8-inch squares and in a variety of smooth, textured, clear, and diffused styles. Before choosing your glass, decide how and where it will be used, so... Read More »
We'll start by measuring out our fishing line, our nylon fishing line. We want to double our fishing line because we want an extra strong string. And we're going to measure out double the full length of the pattern plus another half length. And that will... Read More »
Paint options for basement walls and floors 68tele Painting 8 10-28-2009 08:09 PM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 10:17 AM
Attaching CMU partition walls? figs Building & Construction 14 06-15-2009 06:02 PM
Staining Interior Basement Concrete Walls techinstructor Painting 0 03-15-2009 04:15 PM
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 17 07-25-2008 06:59 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
