ACQ Indoors? - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-27-2008, 09:49 AM   #1
Question
ACQ indoors?
Hello,
my question is,
Is Top Choice ACQ Type d -2 X 4 lumber permitted to be used indoors as studding for a finished basement, I will build a wall approx 2 " from masonry, I know the plates need to be press treated, but i want to use pressure treated for the studs also, are there any codes against this or are there any hazards to be concerned about.
Please respond.
Mark form New Jersey
mark s is offline   Reply With Quote
Old 05-27-2008, 10:13 AM   #2
Jay123's Avatar
I don't now about code, but I would be worried more about twisting/warping. PT seems to do a lot of that.
J
Jay123 is offline   Reply With Quote
Old 05-27-2008, 07:21 PM   #3
Registered User
Termite's Avatar
There's no code that prohibits doing it, but it is a terrible idea. The building inspector will probably tell you that as well. No offense intended, but if it were a good idea, you'd see professionals doing it.
It will look great until you turn your furnace or air conditioner on, and the stuff really starts drying out. Southern Yellow Pine goes CRAZY when the moisture evacuates from it.
Use ACQ for your bottom plate and frame the rest of the basement with untreated lumber. The only application where ACQ should be used indoors is when it is in direct contact with concrete.
Trust me on this.
Old 05-27-2008, 08:50 PM   #4
remodeling pro
It is not a code problem, but a very bad idea. Unless you are willing to use all #1 KDAT (read$$$$), the other stuff will warp, twist, and shrink so bad that you will regret it, gauranteed.
troubleseeker is offline   Reply With Quote
Old 05-28-2008, 06:05 AM   #5
ACQ will also eat up conventional sheetrock screws or nails,on top of twist and warp problems.
bayoudonnie is offline   Reply With Quote
Tags
acq indoors
using compressor indoors matchley Safety 12 12-07-2008 11:32 PM
Painting Kitchen Cabinets (part 2) - Which Paint Gun/Sprayer? 1655graff Painting 5 10-05-2007 11:10 AM
Bath fan vented indoors? tjandt Plumbing 6 02-10-2006 10:44 AM
Moving water heater indoors... MLO Plumbing 1 02-04-2006 01:33 AM
