Ac Install - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-01-2007, 11:45 AM   #1
Ac Install
I am trying to figure out the best way to cut vinyl sidind to put a AC unit in the side of the house. How do i wrap the J-channel around the AC and nail it so it looks nice. Thanks for your advice
Jmontgom
jmontgom is offline   Reply With Quote
Old 07-01-2007, 01:22 PM   #2
Eibwen
Are you putting in a window type unit and if so, is it going in a new opening versus a window?
Sammy is offline   Reply With Quote
Old 07-01-2007, 03:08 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Jmontgom
You would have to remove the siding that is in the area that you plan on installing your AC unit.
Go thru all the steps of installing the AC unit (that is a whole nother ballgame):
see: http://www.creativehomeowner.com/index.php?
Important: Make sure that you seal that AC unit up good before you install the Vinyl siding.
The J-channel is installed on the exterior wall sheathing using 1 1/4" roof tacks (NOT onto the AC unit). If you want to know more about installing this, see this link and study the section on installing J-channel around windows:
http://www.doityourself.com/stry/h2installvinylsiding
The application would be the same around your AC unit. Again, make sure that you properly weather-seal around the AC unit itself, prior to re-installing your vinyl components.
- Build Well -
Need to install a water pressure regulator Doug Crf Plumbing 2 06-20-2009 02:23 PM
cutting shingles to install gutters Chicago Bill General DIY Discussions 2 02-27-2009 06:42 AM
Repairing Bad Crown Moulding Install jirishboy Carpentry 10 10-02-2008 10:05 PM
Plantation Shutters: Professional Install or DIY? SlaveToTheWife Remodeling 1 06-01-2007 02:27 PM
Maxx Shower Walls Install on Metal Studs? atilla137 Plumbing 2 11-21-2006 07:17 PM
