I have a 9 1/4" opening (total width of wall including 5/8" sheetrock on each side) that I need to find a pre-hung 48" double raised panel door to fit - each door needs to be 24" wide by 80" tall.
Is it possible to buy a pre-hung door with a door jamb this wide? If so where - brick and mortor location or internet okay. Need this for a home in Houston, Texas.
You are using full 8" studs? How's that work? Sounds like special order to me unless you have real carpenter skills and don't mind some jamb extensions.
we used the split jamb pre-hung doors on a house that had a 12 inch interior wall. it was a modular and the doors were between the 2 sections. we got it from a door supplier. the split jambs were trimmed on both sides already also.
Today at lunch I will go to a "real lumber" yard as opposed to Home Depot or Lowe's and give that a try. Will let you know the result.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
