6" Wide Door Jamb Opening?? - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-15-2008, 08:17 PM   #1
6" wide door jamb opening??
Sorry for the rookie question, but what's the best way to install a pre-hung door on a 6" wide (including drywall) door jamb opening? Most of the jambs I see in home improvement stores appear to be about 4.5" wide. Do I need to order a door with a wider jamb?
Thanks.
floxy is offline   Reply With Quote
Old 01-15-2008, 08:21 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Create (fabricate) extensions jamb for the door.
Example - Scroll down to the pictures to get an idea:
LINK: Framing around 4" metal pole
- Build Well -
Old 01-15-2008, 08:23 PM   #3
Yes. Are you sure the the wall isn't 6.5" wide? (thinking 2x6 with rock)
Joining_Heads is offline   Reply With Quote
Old 01-15-2008, 08:54 PM   #4
I think it's 6" including sheet rock. Because the door opening is under a large beam I had to butt the narrow side of a 2x4 along side of my normal 2x4 door jamb. One 2x4 wide, one 2x4 narrow and two sheets of 1/2" drywall should be 6".
The pics provided by Atlantic are great. Thanks for the help.
bamboo flooring: wide or narrow boards? blakekr Flooring 4 11-09-2007 03:29 PM
Header size for wall opening firebirdbd Building & Construction 1 08-07-2007 05:11 PM
opening through party wall arise Building & Construction 13 02-16-2007 04:33 PM
Framing Opening Length captainron19 Carpentry 3 04-01-2006 10:50 AM
arched opening ITE Remodeling 5 12-09-2005 05:14 PM
