Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 05-30-2010, 02:18 PM   #16
5-1/4" door jam?
I am replacing the complete whole frame because the current wood is damaged and starting to rot (the rot is isolated to the door frame and does not effect the structure at all)
Otherwise I would just do a slab door.
cbzdel is offline   Reply With Quote
Old 05-30-2010, 02:39 PM   #17
nap
You talking to me?
nap's Avatar
5-1/4" door jam?
so, what you need to do is purchase a door with a 6 9/16 jamb (which is for a 2X6 wall framing material) and either you cut it down or have it cut down for you.
Lowes can get you special sizes if you want them to do it for you.
For you to cut it down, you would need to remove the brick moulding and cut back the side and top boards to whatever dimension you need and then reinstall the brick mould.
It is better to cut down the 6 9/16 that use a 4 9/16 and an extension IMO.
Old 05-30-2010, 02:46 PM   #18
A "Handy Husband"
rjniles's Avatar
5-1/4" door jam?
Sorry but I disagree, unless you disassemble the frame so you could trim it on a table saw, it will be very difficult to get an even cut. Adding extension jambs is much easier.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 05-30-2010, 03:09 PM   #19
nap
You talking to me?
nap's Avatar
5-1/4" door jam?
to each their own.
Old 05-30-2010, 03:54 PM   #20
Moderator
kwikfishron's Avatar
5-1/4" door jam?
I’ve put in doors that came from Lowes with T&G jamb extensions.
The jamb on the door had the groove and the extension had the tung.
Put in the door rip the extension glue in and done.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
Old 05-30-2010, 04:25 PM   #21
Tom Struble's Avatar
5-1/4" door jam?
you know,if this door is in an exposed location you may be better off using a jamb made out of a composite material,in that case id special order it
Tom Struble is offline   Reply With Quote
Old 05-31-2010, 01:35 AM   #22
5-1/4" door jam?
nope, covered porch
I bought the door for a 4-1/2" wall.
While at the hardware store I spoke to the door "specialist" and he told me what he recommended. He said remove the brick molding and trim the brick molding in a table saw to the correct thickness then reattach it, then use your own trim on the outside of the door, trim that matches the rest of your house.
What do you guys think? It makes since to me, as the brick mold looks nothing like the rest of the trim on my house.
Old 05-31-2010, 09:14 AM   #23
5-1/4" door jam?
if the origional door was under a covered porch ...why did the frame rot?
Old 05-31-2010, 09:32 AM   #24
A "Handy Husband"
rjniles's Avatar
5-1/4" door jam?
Originally Posted by cbzdel View Post
nope, covered porch
You are going to cut the brick mold down to use as an extension jamb? Why?
Use 1" clear stock or composite trim board
Old 05-31-2010, 11:59 AM   #25
5-1/4" door jam?
the door is the original door from the 40's, a covered porch was built within the past 3 years.
Old 05-31-2010, 12:03 PM   #26
5-1/4" door jam?
figured then I would not have to buy any wood, I have lots of exterior trim left over, it seems as I could just run the existing brick mold down a table saw and my problem would be solved. If its a bad idea I will stay away.
Old 05-31-2010, 12:17 PM   #27
Moderator
5-1/4" door jam?
It will work just fine.
-NEW MEMBERS-
Old 05-31-2010, 12:18 PM   #28
A "Handy Husband"
rjniles's Avatar
5-1/4" door jam?
Usually the brick mold is finger jointed pine. When you mill it down small enough to use as an extension jamb it will be very flimsy at the joints. I would use a composite board to cut the extensions and composite exterior trim. But as NAP said; "to each his own"
Old 05-31-2010, 01:25 PM   #29
5-1/4" door jam?
you know you can buy a 2500$pre hung door and unless you specify they always put them in those 15$ frames,that fj white ''wood'' is junk
1/4" water line install BlueBSH Plumbing 6 12-15-2009 10:59 AM
Are there 1/4" drain augers with replaceable heads? darsunt Plumbing 0 12-05-2009 01:50 PM
Can I use 1/4" drywall on a ceiling? churchlady Drywall & Plaster 12 11-25-2009 09:43 AM
Transition from Hardwood to Marble Tile (1/4" lip)??? tigerbalm2424 Flooring 5 11-17-2009 08:18 AM
Building up concrete 1 1/4" tomptat Flooring 6 08-17-2009 11:27 PM
