Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 01-29-2011, 04:40 PM   #1
Question
45 deg angles on the 1 side of a 1xX
is there a trick to making perfect 45 deg angles on the 1 side of a 1xX with just a circ saw and a carpenter triangle (for the baseboard corner joints) ?
i know how to do it with 2xX lumber because it will stand solid on the 2 side but don't know how to do it with 1-by lumber.
Old 01-29-2011, 05:29 PM   #2
Carpenter
dtsman's Avatar
Not really. It will never be perfect using a regular circular saw. Like you said, it is easier with 2 x wood. The reason being the board has more meat on it to help keep the blade from floating. Miter saw is still the best way.
You could build a jig box with guides for both sides of your saw to keep it from floating.
Bo
Remember,
If the women don't find you handsome,
they should at least find you handy.
(Red Green)
dtsman is offline   Reply With Quote
Old 01-29-2011, 05:30 PM   #3
You lay it flat on the cutting surface and set the saw at 45 Degrees. I'd use a bevel guage to see if the angle is indeed 45. If not, you can adjust the angleon the saw before you cut.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
amakarevic (01-30-2011)
Old 01-29-2011, 06:11 PM   #4
use scrap material to make sure the two cuts form 90*
mrgins is offline   Reply With Quote
MAYTAG Side X Side dripping Water Dispenser junior1263 Appliances 1 10-23-2010 08:34 PM
GE side by side JohnJak Appliances 1 09-29-2009 09:41 PM
Kenmore side by side refrigerator not cooling bidderbl Appliances 1 09-26-2009 07:48 PM
GE Side by side water dispenser not working cfinchapex Appliances 3 09-19-2009 11:39 AM
Very Small leak at Shower Valve on Cold Water Side, Threaded. Tighten it more or ? twilightcall Plumbing 3 08-25-2008 09:19 AM
