Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 03-25-2011, 01:33 PM   #1
Still Learning
4 1/2 inch baseboards
Hey all. Im putting in 4 1/2 baseboards in a finished space. The problem is, behind the drywall is alluminum framing. Plus the wall is not straight in some spots. I tried liquid nail AND finish nails but its not too sturdy. Any suggestions? Thanks
thehvacguy is offline   Reply With Quote
Old 03-25-2011, 02:16 PM   #2
Old School
Willie T's Avatar
Finish (trim head) screws.
Willie T
Old 03-25-2011, 09:20 PM   #3
Still Learning
??? They make finish screws?
Old 03-25-2011, 09:31 PM   #4
Old School
Willie T's Avatar
Google "finish screws".... and check out IMAGES. Sold at all Home Depots.
Willie T
Old 03-26-2011, 12:38 PM   #5
When I frame with metal studs, I install a plywood base at the bottom of the wall to ease the baseboard installation. It will be 1/2" shorter then the planned base molding.
Ron
Old 03-27-2011, 01:34 AM   #6
Ron
Exactly what I was going to suggest. It will be a bit of work to cut out the drywall, but it is the only way to go in my opinion.
rubberhead is offline   Reply With Quote
240V 2 pole 1/2 inch GE breakers? Isaac-1 Electrical 12 02-09-2010 12:21 PM
Masking off baseboards 2 PaintedSurface Painting 1 01-18-2010 05:30 AM
14 inch tank on a 12 inch bowl? jimmybush Plumbing 2 10-02-2009 02:13 PM
Water Heater 1/2 inch pipes tke402 Plumbing 7 10-04-2008 12:19 PM
new 41/4 inch tile does not match old 41/4 inch tile sweet123 Flooring 2 12-27-2007 09:53 PM
