2x8 Span - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-18-2011, 07:10 PM   #1
2x8 span
will a true 2"X8" span a 16' area and have enough support for a floor at 12" centers
dannyelson is offline   Reply With Quote
Old 12-18-2011, 07:19 PM   #2
Framing Contractor
Rewards Points: 118
Nope.
sixeightten is offline   Reply With Quote
Old 12-18-2011, 07:28 PM   #3
Registered User
Rewards Points: 5,482
Yep, a sleeping room or attic floor, of certain few species and "Select structural" grade, if under the IRC; http://publicecodes.citation.com/ico...002_par017.htm
Gary
Old 12-18-2011, 07:57 PM   #4
wareagle's Avatar
go here and check it youself.
http://www.awc.org/calculators/span/...rcalcstyle.asp
wareagle is offline   Reply With Quote
Old 12-27-2011, 02:20 PM   #5
Retired carpenter
You would be much better off using 2x12s at 16" O.C. If you have to stick with 2x8s, I would use double 2x8s at 16" O.C.
abracaboom is offline   Reply With Quote
Old 12-28-2011, 07:41 AM   #6
I can't speak for a 16 foot span, but I have several 13 foot spans (true 2x8) in my old house which are holding up well. Granted, the lumber may be a bit better quality than what is available today..........and after 100 years there is admittedly a bit of sag here and there.
That's just my opinion. But it's free, so take it for what it's worth to you.
1910NE is offline   Reply With Quote
Old 12-28-2011, 06:51 PM   #7
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,114
if im using 2x8's i space them 12"o.c.. ive seen new decks that had 2x8 joists with a 12' span and had quite a bit of bounce in them . not a good thing for a new deck
i strongly suggest switching to 12 " o.c and adding 2 or 3 rows of blocking to help stiffen it up
woodworkbykirk is offline   Reply With Quote
Old 12-28-2011, 07:52 PM   #8
Civil Engineer
Rewards Points: 4,690
All joists used in residential construction must be evaluated both for strength and deflection. Without detailed information about the load your joists are required to carry, which is TYPICALLY determined by code considerations, it is not possible to determine if your joists are adequately strong or adequately stiff. If you happen to have lumber which meets the specific criteria in your code book, you can evaluate the stiffness and strength for a given room type loading, however you stated that you have "true" dimension lumber, therefore you are not going to be able to use standard tables. Of course, if you are planning to construct without a permit, and not to code, then you can evaluate the adequacy of your joists any way you see fit, including taking advice from an internet chat forum.
Center bearing vs. Clear Span floors -- Span Tables WaldenL Building & Construction 2 02-24-2015 06:50 AM
Pergola construction - beam span without sagging fahartle Building & Construction 9 07-25-2010 07:54 PM
How to calculate Joist span table for 3x8's WillSTX Building & Construction 22 03-19-2010 04:41 PM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 12:08 AM
Patio Roof Beam Span slakfu Building & Construction 4 06-03-2009 10:45 PM
