2x6 Exterior Corner Framing, Tie Downs... - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-08-2011, 03:30 PM   #1
2x6 exterior corner framing, tie downs...
Hi all,
I'm noodling the placement of the StrongTie STHD10RJ's in my stemwalls, with respect to the wall framing above. I have two corners made up of "alternate braced panels". I need to place two STHD's in the corners on adjoining walls. THere's not enough room to put them both in the corners so one is going to have to move down the wall a few inches. What make up is everyone doing for framing up 2x6 corners?
Thanks,
Cam
CamSweet is offline   Reply With Quote
Old 08-08-2011, 05:05 PM   #2
Rewards Points: 150
When we have conflicting areas like that, the foundation people will usually move it down to the next stud spacing so it ends up on a stud. Sometimes we are required to put an additional HD3B Simpson fastener at the corner. You don't really want to use these as they are a major pain to install. They require us to put them in with 3/8" x 8' lag bolts into the concrete and we must double stud the wall so we can use 1/4x 3" lags into the studs. You'll need to ask the engineer, if an engineered foundation or the inspection agency (city inspector), if this is an acceptable practice in your area.
TrapperL is offline   Reply With Quote
pocket hole jointery and cabinet screws for framing newbymodeler Carpentry 29 03-07-2013 04:17 PM
Any opinions on panelized framing? TitaniumVT Building & Construction 5 12-29-2009 02:56 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 04:49 PM
Framing Gun - Nail Shank Diameter Questions... MoparAutoworks Building & Construction 5 07-03-2006 10:27 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 05:23 PM
