2x4 Structural Integrity - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-13-2013, 09:36 AM   #1
2x4 Structural integrity
I'm new today to the website, so please overlook any mistakes i make. i have a house under construction, it's under roof and the plubming work has started and soon the electrical. On an interior non-load bearing wall, the plumber drilled holes through the wall studs to run a drain pvc to the main drain line for the bathroom. I guess the holes are about 1 3/4 inch and are off center. Therefore the outer edge of the hole is very close to the side of the 2x4 and in one stud, the hole broke the side of the 2x4. After running the pvc he nailed a metal plate on the 2x4. I asked the plumber if the hole would weaken the structural integrity of the 2x4's, he said the plate would reinforce the strength and therefore no loss. I thought the plate would be to protect the pvc from dry wall nails. Finally my question - does the plate help or do i need to request the work be re-done. Thank you.
dr. iknowitall is offline   Reply With Quote
Old 03-13-2013, 10:53 AM   #2
Rewards Points: 358
the plate does not give any structural integrity to the stud..
but with it being a interior non-load bearing wall there is not alot to be worried about, its only holding up the drywall..
cbzdel is offline   Reply With Quote
The Following User Says Thank You to cbzdel For This Useful Post:
woodworkbykirk (03-13-2013)
Old 03-13-2013, 11:00 AM   #3
Rewards Points: 13,300
This is what's I call a wet wall.
It would have been better to have used a 2 X 6 wall in that area, but what's done is done.
I believe the maximum size hole was suppost to be no more then 1/3rd the size of the stud.
He should have at least used a nail plate like this to strenthen the stud.
http://www.bing.com/images/search?q=...ectedIndex=153
Old 03-13-2013, 11:36 AM   #4
Roofmaster
Rewards Points: 2,172
He really should have drilled in the middle of the stud. If you are really concerned, you could add 1 x 3 pine to the side of the studs on the wall in question on the flat, therefore making a T. This should add enough strength and give you a little more depth. You have to consider your toilet flange though.
What about the drain lines? Joe is right in that the plumbed wall should be at least 2 x 6 (5.5")
Old 03-13-2013, 12:07 PM   #5
Thank you!!!
Thank you cbzdel, joecation and jagans! Your reply will cause me a little less stress. I thought if it was an interior wall the holes in the 2x4's shouldn't be a problem. However with the nail plate or a 1x3 as reinforcement it won't be a problem.
This is a great website - your advice is vaulabe. I can only offer help if you have a problem with dehydrators(jerky) or outdoor smokers (see Klose smokers).
Old 03-13-2013, 12:16 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 452
What your plumber did is industry standard these days. If it's a non-bearing wall- you need not be concerned.
Nail plates are required when a pipe is within 1.25"(I think) of the edge. It's not uncommon to use 50 plates in one house.
Old 03-13-2013, 12:58 PM   #7
Rewards Points: 6,652
That wall should have been 2x6, not 2x4. Even the outside perimeter walls should be 2x6 for better insulation of the envelope.
The Following User Says Thank You to gregzoll For This Useful Post:
Old 03-13-2013, 12:58 PM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 1,194
If your really worried about it....you could use one of these....
ddawg16 is online now   Reply With Quote
The Following User Says Thank You to ddawg16 For This Useful Post:
GBrackins (03-13-2013)
Old 03-13-2013, 04:46 PM   #9
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,060
by code no wires or pipes are allowed to be within 1 1/4 of the edge of a stud. i wouldnt risk it with the plate the stud will still be flimsy.. either replace the stud or fur teh wall out to a 2x6 wall
woodworkbykirk is offline   Reply With Quote
Old 03-13-2013, 05:26 PM   #10
I posted that one 4 post ago.
Old 03-13-2013, 05:27 PM   #11
JOATMON
ddawg16's Avatar
It would appear that I'm as lazy as the rest....with out a pic in the post....I don't look at the links....
gregzoll (03-13-2013)
Old 03-13-2013, 05:30 PM   #12
Plumber
Rewards Points: 452
says the man with 3 links in his sig
Old 03-13-2013, 05:33 PM   #13
JOATMON
ddawg16's Avatar
Ok....busted........
Opening up a load-bearing wall. Do I need a structural engineer? Ironlight Building & Construction 3 04-18-2011 12:03 PM
Cracks in 10 yr old house drywall tenthirtytwo Drywall & Plaster 9 03-16-2011 12:33 AM
Treefort / treehouse structural integrity syler Building & Construction 14 02-11-2011 11:47 AM
Structural integrity question Red Squirrel Building & Construction 8 07-28-2009 11:02 PM
Structural integrity of fir 6x6 beams ashen Building & Construction 8 07-31-2008 07:31 PM
