2x4 And 4x4 Load Capacity?? - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-27-2013, 12:19 PM   #1
2x4 and 4x4 load capacity??
i am planning on building a small shed (about 8'x6'). it is going to be used for firewood storage, so it is not going to be fancy. i am not going to bother with a floor (its going to be a dirt floor), and i think instead of sheathing i am just going to hang tarps to keep the water/snow out.
to save money on materials i am not going to frame with studs; i think i am just going to put a 4x4's for the corners and maybe one in the middle of each 8 foot wall. also i will be doing a metal roof so it will not be very heavy. so what im asking is how much weight can one 4x4 support? would one 4x4 on each corner be sturdy enough?
also, to make it a little more sturdy i will probably have 2x4's at the bottom and halfway up the shed connecting the corner posts together.
the point of this shed is not to be pretty, it's just to store firewood and i want to spend as little money as i can for it to do its job.
thanks in advance
ttamd is offline   Reply With Quote
Old 02-27-2013, 12:23 PM   #2
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 938
2X4's will do what you want.
You need some diagonal bracing to keep it rigid.
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is online now   Reply With Quote
Old 02-27-2013, 12:26 PM   #3
you think that i could just use 2x4's for the corners also? i don't need any 4x4's?
Old 02-27-2013, 02:57 PM   #4
123pugsy's Avatar
Rewards Points: 938
Rethinking this because of the dirt floor and purpose.
2x4's are OK, but four pressure treated 4x4's at the corners set into concrete would give good stability and would probably cost only a bit more. 2x4's to tie these together and still use diagonal bracing as well.
One more thing, if it's close to your house and you're a light sleeper like myself, the sound of tarps blowing in the wind can keep a guy up at night.
Old 02-27-2013, 05:32 PM   #5
Rewards Points: 636
you can do it cheaper all you have to do is find some one in your area with pallets they want to get rid of i find mine on craigslist
just google wood pallet sheds and look at the images
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Tags
shed
