2x10 Span - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-26-2011, 03:29 PM   #1
2x10 span
will a 2x10x16 that you buy at home depot spane 15 feet 16.oc.
biglou1957 is offline   Reply With Quote
Old 11-26-2011, 03:35 PM   #2
DIY staff
Rewards Points: 7,174
Are you talking about a floor?
House--deck--barn?
Old 11-26-2011, 05:05 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,334
species, region ?? required to answer this question to be up to code
woodworkbykirk is offline   Reply With Quote
Old 11-26-2011, 05:30 PM   #4
Civil Engineer
Rewards Points: 4,942
A 2x10x16 by definition is 16 feet long, so it certainly will span 15 feet. Whether it will hold up the load you are planning to put on it is an entirely different question, but since you did not ask, I am not telling.
Daniel Holzman is online now   Reply With Quote
The Following 2 Users Say Thank You to Daniel Holzman For This Useful Post:
Willie T (11-26-2011), woodworkbykirk (11-26-2011)
Old 11-26-2011, 05:56 PM   #5
Rewards Points: 150
Determine the Use
biglou1957; Assuming that you are using the 2 X 10 for floor joists; You need to determine what the live load requirements are and the dead load; e.g. in a one-family dwelling, for sleeping rooms the live load is typically calculated at 30 pounds per square foot and for other habitable space (living room, great room, den, kitchen) the live load is typically 40 pounds per square foot. The dead load will usually be calculated at 10 pounds per square foot. The span you get depends on the species of the wood and the grade, e.g. doug fir, hem-fir, #1 , #2. Other factors can also play into the span such as if you live in a high wind zone or seismic area.
It sounds like your work is structural and in most areas this requires a building permit and therefore the plan review process. Your proposal, if for floor joists in a one-family dwelling, if for floor joists, if not in a high wind or seismic area, if no less than #2 hem-fir, if 16" on center, should do it, but come back with more specific information. If these are joists for a storage area let us know what you are storing. There is some very good talent contributing to this site and it you provide specific information someone is likely to know the answer.
TheCamper is offline   Reply With Quote
The Following User Says Thank You to TheCamper For This Useful Post:
Old 11-26-2011, 09:58 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Don't wait for more information from the OP guys just run-on with anything that comes to mind.
Old 11-27-2011, 10:06 PM   #7
have to refer to your local building code...i'm sure the building inspector will want to see what you have planned before you go ahead and build it, however.
chrisBC is offline   Reply With Quote
Old 11-28-2011, 06:24 AM   #8
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
You ask if "a" 2x10 will span that far. How many are we talking about? Where are you building? Look in the UBC book. In a word, yes. We span 16' all day long for floor joists under live loads here in the Midwest. Cali and Flo...might have to bump up to 2 x 12.
titanoman is offline   Reply With Quote
Center bearing vs. Clear Span floors -- Span Tables WaldenL Building & Construction 2 02-24-2015 06:50 AM
2x10 Joist working load 14' span rebar Building & Construction 5 08-19-2010 01:52 PM
How to calculate Joist span table for 3x8's WillSTX Building & Construction 22 03-19-2010 04:41 PM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 12:08 AM
Patio Roof Beam Span slakfu Building & Construction 4 06-03-2009 10:45 PM
