2-tier Kitchen Island - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-22-2007, 08:27 AM   #16
yummy mummy's Avatar
Rewards Points: 1,016
atlantic
Thanks Atlantic.
I do realize it all depends on what you want in it.
I think I did ok with it.
Thanks again.
yummy mummy is offline   Reply With Quote
Old 03-22-2007, 07:23 PM   #17
2-tier island
Here are some construction photos of an island I made a couple of years ago for customer. The only area for stools is at the end of the 'L'
http://www.csprep.com/images/island1.jpg
http://www.csprep.com/images/island2.jpg
http://www.csprep.com/images/island3.jpg
http://www.csprep.com/images/island4.jpg
http://www.csprep.com/images/island5.jpg
http://www.csprep.com/images/island6.jpg
http://www.csprep.com/images/island7.jpg
Hope it helps and gives idea as to what can be done.
coyotehills is offline   Reply With Quote
Old 03-23-2007, 12:30 PM   #18
Island
I used a 2x6 along the back side of the cabinets then skinned the whole thing with inch maple. I also insolated between the 2x6s for sound when the kids stick their feet back there. On the sides I also skinned with and run it past the 2x6s. In the front of the cabinet I carefully put the iron on veneer maple to get the finished edge. I removed the existing veneer with a razor blade and used a wider piece to cover the whole area. You could just try to cover the but I didnt want the seam. I also purchased maple corbels for strength.
HAASEMAN2003 is offline   Reply With Quote
Old 03-23-2007, 12:33 PM   #19
I heard doing furniture (island is an example) is more difficult than general renovation.... so even though I almost finish renovating the basement... making an island is still out of reach in my mind.... I did make a book case for my 2 years old before... it is very useful and handy... but in terms of look.... I wouldn't want to comment on it...
KUIPORNG is offline   Reply With Quote
Old 03-23-2007, 12:43 PM   #20
Playing around
We all start some where and all have stuff that we can look back on. In the end it is all fun. I don't know if someone else would like some of the stuff that I have done. It is mine and I have alot of fun playing around with it. I am a computer system administrator not a finish carpenter. If my Boss (Wife) is happy with it thats all that matters. I have started over plenty of times. gets alittle expensive but fun.
Old 03-23-2007, 12:46 PM   #21
I bet you don't have babies running around you in circle to allow you have this luxury use of time....
Old 12-16-2007, 07:13 AM   #22
I need to know how high the 2-tier island should be for a bar stool to fit comfortably . Thanks Jones
jones is offline   Reply With Quote
Old 12-16-2007, 07:15 AM   #23
How high should the 2-tier island be if you have the sink on the lower portion and you want bar stools?
Old 12-16-2007, 12:08 PM   #24
Rewards Points: 264
My bar is 32" to the work surface and 45" to the bar top surface.
My island is 36" to the top of the work surface and 42" to the top of the eating surface.
I'm 5'9" and work at the butcher block top on my island every day. It could be 2" higher. The height of the island is great for eating on. The bar is a tad too high to be comfortable to eat at.
Jeekinz is offline   Reply With Quote
Old 02-06-2008, 02:35 PM   #25
Attaching wall
This is the same kind of island we would like to build in our new kitchen. Can you let me know first what is the knee wall made out of (2x4 or 2x6). And how did you attach the knee wall to the floor? Did you just screw it down to the floor. Was that enough strenght?
anderson79 is offline   Reply With Quote
Old 02-06-2008, 04:37 PM   #26
Rewards Points: 5,336
All you have to do is order some finished 3/4" stock from the cabinet company and let the contractor fabricate the upper tier. How it's made depends on what configuration you chose for the stool side.
Ron
kitchen Island outlet richardremodeler Electrical 8 06-05-2007 05:45 PM
Design Help on Kitchen Island cstrat Remodeling 12 04-01-2007 08:19 AM
got rid of kitchen island, how to get rid of the electrical wire from floor ckcrew Electrical 15 12-14-2006 09:45 AM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 10:23 PM
Sink or No Sink in Kitchen Island? Not Sure Plumbing 4 08-29-2006 07:37 PM
