1x8 Pine Plank Walls In A Bathroom - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-21-2014, 07:55 PM   #1
RustyRealtor's Avatar
Rewards Points: 287
1x8 Pine Plank Walls in a Bathroom
Hello All,
I am re-doing a small bathroom for some friends in a 1930's house. They want 1x8 clear pine planks on the wall and ceiling with a nickel size gap between each board. I plan to use 16 gauge finish nails to attach the pine to the studs. The pine will then be pickled with white paint. My question: do you think the boards will cup over time?
Thanks Very Much,
Russell
RustyRealtor is offline   Reply With Quote
Old 02-21-2014, 08:10 PM   #2
Rewards Points: 14,000
There going to cup, impossible to clean where the gap is and be a dust catcher.
I'd at least seal the boards on all sides before installing.
Sounds like something they saw on one of those silly DIY shows.
Why the gap, T & G would be a much better idea and most of the nails would not show.
Old 02-21-2014, 08:19 PM   #3
Davejss's Avatar
Rewards Points: 776
As Joe says, at least seal all sides and edges or they will cup for sure. Probably will any way, but sealing every part of the board will help. Put in the best exhaust fan you can find. Moisture and pine boards are like oil and water. Good luck!
Davejss is offline   Reply With Quote
Old 02-21-2014, 08:29 PM   #4
kwikfishron's Avatar
Rewards Points: 800
I wouldn't use a finish gun on something like that. If their going for that old rustic look then what's wrong with hand nailed siding nails? If they don't want to see the nails then I'd “toe screw” it with trim head screws and glue.
Whatever you do Sheetrock it first and paint that black (at least where the gaps are going to be). Also install the boards bark side out...Better to have a bump than a cup with something like that.
kwikfishron is online now   Reply With Quote
Old 02-22-2014, 04:52 AM   #5
Rewards Points: 287
Thanks for the replies. I will let you know how it goes.
Russell
Old 02-22-2014, 09:38 AM   #6
Rewards Points: 808
Are you married to the pine idea?
IslandGuy is offline   Reply With Quote
Old 02-22-2014, 06:52 PM   #7
Rewards Points: 287
Hello Again,
I should've mentioned earlier, the house is in Nashville, not Florida. The friends bought their lumber today. They bought spruce instead of pine. It's nice looking stuff. They are going to make kerf cuts on the back side 1/2" apart and 3/8" deep along the entire length of the boards. Then they are going to apply poly on the back side and ends. These are recommendation of the lumber yard, not me. I suppose it makes sense, but it sure will take some time. They're going to cut the kerfs tomorrow and I'll install on Monday. Stay tuned.
Thanks Again,
Russell
NEC - what is the purpose of some of these codes ? chez bouton Electrical 32 12-17-2013 02:04 PM
Newb: Tiling alcove bathroom walls w/ flush-mounted window PairOhLegal Kitchen & Bath Remodeling 0 07-08-2013 11:35 AM
the proper way to do bathroom walls? Mistifire Kitchen & Bath Remodeling 17 06-16-2013 04:16 PM
Beadboard wainscotting walls in bathroom jmorc2003 Remodeling 19 01-08-2013 09:58 AM
Finishing Basement Walls, Inside Perimeter Drains, and Moisture, Oh My BSponz1 Building & Construction 1 02-08-2011 01:20 PM
