18" Wide Formica Countertop On Half Wall? - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-28-2010, 10:52 AM   #1
18" wide formica countertop on half wall?
I am worried about weight. I was going to build a 2x4 studded wall to save a little space but i am worried about the weight of the countertop. Is there a formula or a way to go about figuring this so i mess this up?
bs1224 is offline   Reply With Quote
Old 11-28-2010, 11:11 AM   #2
What I've done before on any half wall that may be exposed to stress, is to go thru the floor with a stud every 4' and tie it in to a joist (assuming you have access to the underside of the joists)
mrgins is offline   Reply With Quote
Old 11-28-2010, 12:01 PM   #3
firehawkmph's Avatar
Rewards Points: 1,822
Along with Mrgin said,
If you want to stiffen up a half wall, sheet at least one side with 1/2" plywood, then install your finish sheathing, drywall, paneling, etc. Your formica top isn't all that heavy, but it will require some additional support in the way of knee bracing or the like to keep it from sagging.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 12-02-2010, 06:37 PM   #4
Rewards Points: 5,336
The overhang needs to be supported. A 4 1/2" wide wall will not support this size counter by itself. You will need shelf brackets or corbels.
Ron
Old 12-02-2010, 08:56 PM   #5
jlhaslip's Avatar
Rewards Points: 924
I would mount a piece of plywood to the top of the wall and use it to screw the countertop deck for fastening.
Also, a knee brace on the longer overhang side.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is online now   Reply With Quote
Shower wall, 1/2 glassblock? nkovach Kitchen & Bath Remodeling 0 06-21-2010 09:56 PM
Cutting through masonry wall mwpiper Remodeling 4 04-17-2010 11:30 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
