Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 08-31-2012, 05:08 AM   #1
160 Degree Crown Moulding Install
What would the bevel angle and miter angle be for this? The angle that you see in the picture is 160 degrees.
natethegreat is offline   Reply With Quote
Old 09-01-2012, 11:29 AM   #2
AHH, SPANS!!!
you will probably only be taking out a few degrees per piece to make that angle or try and take it all out of the left pitch angle and see if the profiles still line up, if not then take a little out of the right piece to compensate until the profiles match... a few pieces of scrap crown will help to get the fit.
hand drive is offline   Reply With Quote
Old 09-01-2012, 12:05 PM   #3
you would make a 10 degree cut on each piece.
use some scraps for test pieces and cut like normal for crown.
how have you been cutting the crown so far?
flat in the chop saw or upside down?
for the test pieces try laying flat and cutting a 10 degree miter
Old 09-01-2012, 03:50 PM   #4
The tricky part is the corner to your left lol
If my advise helped you hit "Thanks"
Hammer450R is offline   Reply With Quote
Old 09-01-2012, 07:20 PM   #5
yea cutting that transition piece might take a few tries. one side has to be cut like cutting upside down and the other side has to be a regular flat miter so it ends up being a little sliver.
Old 09-04-2012, 12:03 AM   #6
For some reason I though it would be more complicated and there might need to be some cuts with a coping saw involved. I have a power miter saw to make the angled cuts. Thanks for the replies everyone. I will post another picture or two soon just to make sure I'm on the right track with the other corners.
Old 09-04-2012, 12:09 AM   #7
Here's some corners that I think might be more tricky.
crown moulding paint color doyelc Painting 8 07-14-2012 06:22 PM
Should I add crown moulding to cabinets? NickWa Interior Decorating 5 11-26-2011 08:47 PM
How to match mis-matched crown moulding tooladdict Carpentry 5 10-13-2011 11:55 AM
Crown Moulding on Kitchen Cabinets Pie Carpentry 6 11-03-2009 11:21 AM
Crown moulding - where to buy? sk8z Carpentry 5 05-03-2008 11:37 AM
