16 X 20 Deck Question - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-11-2010, 03:25 PM   #1
Rewards Points: 150
16 x 20 deck question
Passing on a question that was asked to me, and I am not sure either way so I thought I would ask everyone here.
The situation:
Friend of mine is looking to install a 16 x 20 deck, 16' feet against the house and 20 feet out
His house is on a sill wall with a small crawl space. Currently he has a 8 foot sliding glass door with some old concrete steps. He wants to put a 16 x 20 deck.
The question, from F.G. - Finished Grade to the bottom of the sliding glass door is 18 1/2'' when we did the calculations
2 x 6 P.T. as the deck board = 1.5''
2 x 8 P.T. Joist = 7.5''
4 x 6 P.T. Beams = 5.5''
14.5''
Calculate footings up 2.5'' approx and then looked at the Simpson ABA or ABU attachments another 1'' approx.
This would leave no room for a column, is this ok?
I can not see why it would be a problem, and we need to contact the city as they will be the final deciders but wanted to see if anyone has had any experience with anything like this in there personal or work experience.
On a deck this low does anyone have any other suggestions on how they would build it.
Thanks in advance.
canyonbc is offline   Reply With Quote
Old 01-11-2010, 04:14 PM   #2
Rewards Points: 5,336
You would set the sonotubes at the height the 4x6's would be sitting on the standoffs.
Ron
Old 01-11-2010, 04:22 PM   #3
Rewards Points: 150
Ron
Sonotubes - ? - Would that be the the 12'' x 12'' x 48'' concrete form???
So set it up a couple inches so the 4 x 6 beam can rest on the concrete pier??? That is the plan wanted to get everyones thought on the idea.
Old 01-11-2010, 04:47 PM   #4
Sonotubes are just one companies name for cardboard tubes you fill with concrete. They come in various widths.
Ron
Old 01-11-2010, 10:11 PM   #5
Rewards Points: 150
Thank you,
Glad to here a confirmation from somoene else that the design is valid.
Old 01-12-2010, 03:39 PM   #6
Rewards Points: 150
Anyone else??
Any other designs?
Thanks,
Mike
Old 01-12-2010, 07:47 PM   #7
Mike,
Check out www.decks.com - they have some great tools for materials and structural calculations.
How about using standard 5/4 decking for the deck surface?...that will give you a little more room for footings and beams
Brian
brogeflog is offline   Reply With Quote
Old 01-12-2010, 07:58 PM   #8
Thank you,
confirmation is for measurements not the design. You need to take into account loads= material plus lotsa people so how its -designed- needs to be looked at closely
Old 01-12-2010, 08:59 PM   #9
Rewards Points: 150
Originally Posted by brogeflog View Post
Mike,
Brian
Thanks Brian, I will check it out.
Old 01-12-2010, 09:01 PM   #10
Rewards Points: 150
Well Thank you.
The city has the the city engineer sign off on everything to make sure it is code approved and will be "Strong" enough.
my main concern was the measurements line up and at least make some logical since to people and we do not go down the city and get laughed at.
Not the usual TREX deck question... proper water drainage windowguy Building & Construction 2 06-28-2009 10:12 AM
Help Please....Deck post question steve dowd Building & Construction 6 05-12-2009 11:04 PM
Adding on to my mothers deck question. justariot Carpentry 6 03-15-2009 08:09 PM
Two-Level Deck Post Question Melanie337 Carpentry 2 09-24-2007 12:34 AM
deck post question bigjay1151 Building & Construction 4 11-28-2006 08:13 PM
